Question about Whirlpool Refrigerators
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
  • Whirlpool Master
  • 1,606 Answers
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Posted on Sep 05, 2009
2 Suggested Answers
aasc
  • 1606 Answers
SOURCE: I have a Whirlpool refrige. side by side and the
Posted on Sep 06, 2009
My ice maker makes a lot of noise at night I wake hearing it making ice droping sounds. I don't use a lot of ice can I turn the infrared receiving switch to off?
The noise is probably ice dropping into the pan and the normal ice maker and water valve sounds associated with making ice. Most Whirlpool models have a slide cover to "turn off" the ice maker - closing this cover fools the control into thinking the bin is full. Your owner's manual should provide greater detail on this option.
Sep 13, 2014 | Whirlpool Refrigerators
My kenmore side by side is not producing ice and there is a red light blinking inside the freezer sec
Can you locate your model number inside the fresh food section around door frame? I believe you have the ice maker with the electronic eye and sounds like you need to follow these instructions so the ice maker works again. If I am wrong then please correct me by posting your model number that should look like this example=> 321.234567 Click Here=> Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here if you need to ask questions, Sea Breeze
Nov 30, 2013 | Kenmore Side by Side Refrigerator
Whirlpool Refrigerator Icemaker not working
The receiver board has an eye on it (it receives the signal and it may need cleaning. A Q-tip should do. Close the spring loaded panel and insert Q-tip and wipe.
Sep 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Flashing red light on ice maker control
Hi
I have Kitchen Aide refrig. Resently, we had a power surge which seems to have done something to the ice maker control. immediately after it stopped making ice. It has since started to make ice but very slowly. Before the controller blinking red light blinked and paused steady. Now, it blinks two red and pause steady. Is this repairable?
Thanks
Jul 16, 2009 | Whirlpool Refrigerators
Whirlpool Refrig. #ED5FHAXV - Ice Maker Stopped Working
you have a broken cam inside the ice maker module. it happens when the ice maker cant get enough water to completely fill the mold. you need to replace the i/m module with part #W10190935 about 75-100 bucks. also you might want to replace the water filter.
Jan 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigedair refrigator
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Nov 07, 2007 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
548 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
