Question about Karcher Garden
Sprayer hose will not stay screwed on when wter is on and
Karcher electric cold water power washer, Water cable will not stay screwed on when machine is engaged. Sometimes it pos off right away and sometimes I can work for 5 or even 10 minutes before it pos off. Threads are not stripped and I am tymied as to why it will not stay screwed on. I've even tried ABS pipe glue with no success.
    Problem Solver:
  • 7 Answers
You might try loc tite
Posted on Sep 12, 2009
Karcher k 5.700 very low presure and how to fix it thanks
1 water inlet filter clean ?? not limed or ??
2 nozzle clean.
3 pressure control valve properly screwed
Sometimes water hoses are provided with a slot at the hose connection with an internal water seal, which is the wrong way to the water tap instead of to the machine
Jan 23, 2016 | Karcher Garden
Making a shuddering noise and cant seem to get full power
Make sure screen where hose attaches is clean for proper water flow to sprayer, make sure you have good flow from hose supplying water to sprayer. Turn water supply on, and hold handle down to spray, before turning on and see if it helps.
Jul 14, 2011 | Karcher Garden
My Karcher 2400 Pressure Washer will not syphon cleaning fluid. I have a reconditioned machine and the syphon for cleaning fluid has not worked for a while.Everything looks clean but still does not work'...
The black tip nozzle puts the right amount of pressure on the line to draw up the cleaning solution.
If your power washer is like mine, the cleaning fluid adapter is a 'T shaped' brass valve that fits in-line along the hose line.
There is a brass stem sticking out.
The stem has a tiny ball valve on the end.
A plastic hose fits onto the stem, and the plastic hose goes into bucket of cleaner.
As water travels through power washer hose, it creates suction that draws cleaning solution through the tiny ball valve.
The brass ball valve gets clogged or wears out ... we used to replace the stem every so often.
Sherwin Williams used to carry a replacement stem ... but they may not sell little parts any more.
It's been 14 years since I used the suction device.
I got fed up with the thing not working.
We changed over to a pump-up hand-held sprayer for applying cleaning chemical.
The pump-up puts more chemical on the spots where you need it.
So one guy puts chemical on, and second guy comes behind with power washer ... no more replacement parts, and one tip stays in the gun so we never lose a tip.
A pump-up sprayer is half the cost of replacing the T-shaped valve.
Duh-simple is the business model.
Nov 17, 2010 | Karcher Garden
Can you use hot water instead of the normal cold water in the Karcher winner 11. I wish to clean the grease trap of my house.
DO NOT USE HOT WATER!!! This machine is rated for cold water, the pump head is made out of plastic, the plastic pump and electric motor are cooled by the cold water that moves through the pump. If you add hot water into the mix there is a good chance that you are going to overheat the unit.
Just using cold water on the grease trap might do the trick, try using a good quality degreaser, I would recommend a product called 8-Ball, this is a great degreaser and should help to solve your problem.
Oct 25, 2010 | Karcher PSI Electric Pressure Washer
Karcher is spraying water from inside the unit, it actually a k2.97, any ideas please
Hi I have water spraying from air vent/intake on side of my k370 can you help ?
Mar 01, 2010 | Karcher K2.26 Electric Power Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
There is no power when you use the sprayer Karcher K2.89
Depends on the model, but it is probably the pump, Most Karchers do not use expensive pumps. Also, if the end of your hose is off, you won't get much pressure either as it takes a restriction in the end of the hose to increase the pressure. I have commercial pressure washing business & occasionally have an hose end come off, pump problem or high pressure switch problem, but all this stuff can be fixed. Hope this helps you, Rick
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Water coming out of washer
Depending on the model of the machine, it is most likley a cracked control head or split outlet elbow. Remove the covers and run the machine to locate the source of the leak. Ifit is the control head it will spray water from the top just behind the chemical inlet elbow.
Feb 06, 2009 | Karcher K2.26 Electric Power Washer
How can i drain all wter from a sears estate washer while a go o
disconnecting the hoses from under machine( usually pump hose is the lowest, all water should drain from machine, we used to place windshield washer fluid to hold them outside overwinter in used appliance store.
Nov 12, 2008 | Jenn-Air JCD2295HES Side by Side...
Cav4000aww magic chief washer
water is bypassing through the water inlet valve
easy fix go to lowes ect and get a cap plug for a water hose male end and screw it onto the water valve that has no hose connected to it
you could also screw on a water hose sprayer onto the valve if you have one on the end of the garden hose just make sure that it is turmed off
May 17, 2008 | Magic Chef Washing Machines
Garden Logo
209 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
