Question about GE PDW7380NSS Stainless Steel Dishwasher
My Ge triton xl dishwasher, model PDW739n00ss has a green wire with a yellow stripe that is not connected to anything. It is laying on the floor. I cannot find the wiring diagram. Where should this wire be attached?
I HAVE AN OLDER MODEL KENMORE DRYER MODEL NUMBER 86872800 AND A NEWER HOME HOME WITH 4 CONNECTORS DRYER HAS ROOM FOR THREE HOW DO I CONNECT NEW CORD
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
My GE Triton XLdishwasher, model GSD6300 Gooww is leaving a
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 15, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
I am installing a new pump on my asko dishwasher pump but not sure which wire goes where
there should only be two or three wires main wires brown & blue or red & black. green or green with yellow stripes is earth wire main wires connect to pump motor earth connects to earth point hope this helps
Nov 14, 2009 | Asko 1385 Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Moaning Dishwasher
I am still waiting for my response. Your site has not responed yet.
Jun 25, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
The part you need is a WD13X10008 from GE Parts 800-626-2002 or order online at GE Consumer Service web site here
Jan 02, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE TRITON XL REPLACEMENT SOAP DISPENSER?
Best way is to call GE Part at 1-800-626-2002 or go online to www.geappliances.com
Dec 20, 2008 | Dishwashers
GE Triton XL Dishwasher
My Triton XL soap dispenser still has a clump of soap after the cycle has finished. My glasses are left with a cloudy film, and my silverware is left marked with film on it. I have cut down on the amount of detergent, and have not overfilled. I have also tried using white vinegar as the manual states. Any suggestions? Thank you
Aug 17, 2008 | Dishwashers
GE PDW7380NSS Stainless Steel Dishwasher Logo
174 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
