Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
My Sanyo TV just quit working one day after a bad electical storm Its a Model number CLT2054 with an external 12 volt AC to DC converter cord. I thought it may be the converter and replaced it via the internet. That didnt work. I still have not power to the TV. In fact when I plug in the new converter the light on the converter goes out like something is going straight to groung. I cant get the tv to turn on.
    Champion:
  • 222 Answers
Did you bought your replacement AC Adapter on Ebay. well I bought mine on Ebay as well but you know what they're not the exact replacement. I encountered a problem with mine, because of the reverse polarity on the output power. you can fix this though, cut the output wire leading to your TV then connect the white wire with the un-shielded one and to the same on the other wire.
Posted on Jun 15, 2010
My ac adapter seems to have gone bad on my CLT1554 model lcd tv. can I find a replacement?
check the adaptor it will say like 120 ac to 12dv at 1000 ma this what your looking for or go to the back side of the tv like mine says 12 to 18 vDC I think as mine I could run on my car Battery, but power supplys are UL most likley rtatyed and have the specs on the in today tech world power supplied TV or 12 DC and laptops 18-21 vDC when the use LCD technoligy......1000ma =1 amp
Jul 03, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sanyo CLT2054 - power cord has light but when I plug it into the
OK you need a volt meter to check the voltage output of your power pack as two things cause this now enough power out the pack to run your unit or the unit has a short both problems will unlight the light so you need to know if the power supply is working right first as it should say like 120 volts AC in and 12 volts DC 1000 ma out so you will need to mesure this with a volt meter. this is a common problem loading the load of the curcuit as in your TV is mor the the power pack is giving out thus shorting out the power pack of any voltage present, as the little LED light your seeing only takes 5 volts at very ittle current to light and dose not repersent the total voltage output of the power pack itself
May 16, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Have a Sanyo CLT2054 Have flickering picture looks like a strobe; sound is fine
Sanyo CLT 2054 flickering problem is a power supply issue. You don't need to replace it if you can desolder, and solder. Break the case apart that is connected to the ac power cord. Remove the aluminum cover from the DC out end of the PCB. Unsolder, and replace capacitors C9 & C12 (1000mf 16v). Super glue the case back together, and watch TV. Good Luck...............Don't use cheap capacitors use caps that have a low ESR.
Feb 25, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Screen went black
Check the power supply for 12 volts dc, it must provide at minimum 3 amps of power to trigger the on circuit. If not, replace the adapter... if you need one, please contact me.
Jan 12, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Power Cord
Please let me know when I can get the power cord & AC adapter. I moved and lost them and cannot use my television. Thank you R. Werkheiser
Nov 03, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Power cord
DON DE PUEDO COMPRAR UN ELIMINADOR DE 24 VOLT
Apr 29, 2008 | Televison & Video
I DON'T GET A AC POWER CORD JUST THE DC FOR MY VAN.
I'm looking for that TV For my van..we had same tv and now it doesn't work. How much would you sell it for?
Thank you
Mar 30, 2008 | Audiovox AVT1498 TV
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
500 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
