Question about Philips Televison & Video
I have a small Philips TV/VCR combo and I have turned up the brightness menu setting all the way, but any low lit scene is darker than it is supposed to be
  • Steve Allison
    Steve Allison May 11, 2010
    Is this a CRT (picture tube) model? Not a flat panel unit?
    If so,
  • Philips Master
  • 5,568 Answers
Got interrupted-
If this is a standard CRT, there is at least one internal adjustment that can be made and the typical one (located on the flyback transformer) has a tendency to drift with age and reduce the accelerating voltage. In addition, it is possible that the phosphor is aging too so some compensation can be made with the adjustment mentioned. Some sets may also have separate adjustments (usually for two of the three colors) that can be tweaked to compensate for age.
The flyback is the high voltage transformer that produces the horizontal sweep and high voltage for the CRT and often has two adjustments; one for the high voltage (misset this can wash out the screen) and another for focus which can change when the HV is adjusted.
In any set of this type, there are dangerous voltages exposed inside and a well-insulated tool should be used for the adjustment which can accept either a flat blade or Phillips type.
Posted on Sep 05, 2009
I have a Dark picture, so it is hard to see Darker scenes...Can I or How can I Adjust...?
Yes you can. Go into your menu system, picture adjustments, and adjust the brightness level.
Mar 01, 2015 | Philips HTS3410D/37 700W DVD Home Theater...
Philips 50PF9956 50" Black Levels
Did you try backing down the contrast?...about the only thing I can think of would be issues with the main board if its not an adjustment in the picture settings in menu
Nov 23, 2017 | Philips 50PF9956 50 in. HD-Ready Plasma...
My samsung tv ps50b430p2wxxu screen is having problems. when i turn it on its very bright for a few minutes and then comes rite but then after watching for a while it might get very bright again. picture...
sounds like a power supply problem or something that affects brightness is drawing too much current--not a do it yourself fix and price a repair estimate to see if worth fixing or not.
Some of the Samsung sets did have a issue known where the picture flickers with scene changes etc.
That is on the power board and in some cases a jumper on that board needs to be removed-----design flaw well known.
Jun 14, 2012 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
The overall picture is much darker. Night scenes are almost impossible to see.
The brightness settings must have been changed somehow. Just go into your tv menu (there should be a menu button on your remote). Navigate to Picture Settings (this maybe different but there should be something similar) and move the brightness slider up but not too much or the picture will begin to look "washed out". Hope that helps.
Mar 02, 2011 | Hitachi 46F510 46" Projection HDTV
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
Negative effect on Bright areas of Monitor/TV
Try demagitizing the moniter. In the monitor's menu it will have a picture of a magnic , select it. Sometimes it is listed as degrous. After selecting this, your screen will seem to spin then settle. If your still have problems, a magnic may have come close to the moniter while it was being stored, and that will ruin the picture.
Sep 21, 2009 | Computers & Internet
When I am watching a dvd with a dark scene it seems to get even darker almost to the point where I cant see anything.The light scenes are fine. Is there a setting I can change
try adjusting your brightness a little highter up and if you have a LCD tv you can adjust the backlight through your picture/video/image settings in your On Screen Display menu to your television
Aug 07, 2009 | GPX D1816 DVD Player
Sony bravia dims randomly
There should be a setting in the menu of the TV to turn off the auto dim feature (used for adjusting the brightness of the picture depending on ambient room lighting) I don't have a Sony LCD here with me to walk you through the menu settings, but I am certain it is there somewhere. (Chased this issue for the wife who had the same displeasure you're having)
May 04, 2009 | Televison & Video
TV Screen Dims during dark Scenes
Most likely you have the opc feture on. go to the menu under picture setting first option should be to turn on or off the opc. turn it of and should solve the problem.
Mar 18, 2009 | Sharp Televison & Video
Picture is not bright
Hi
Try to re settings your Unit... go to settings then choose color setting then click brightness control or the contras control.
Thanks!
Jan 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
