Question about Nokia 6500 Slide Cellular Phone
6500 Slide doesnt load
When i try to turn it on, phone shows nokia hands theme then goes white for a second, fade to black and turns it off.
I've tried to format using the sequence below: hold this keys inside brackets together [*] [Send] (green) [#] and [Off](red) but didnt load format.
tried USB software upgradating but it doesnt seem to work without the Operating system fully loaded.
White- black screen after nokia logo
you phone was affected by virus you need to format your phone and card
Oct 04, 2009 | Nokia 6500 Slide Cellular Phone
The phone turns on then the screen goes white
Hi Friend,
The problem may be because any software my got hanged or any virus may create this problem so kindly check it out.
Or you may try the below steps,
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card.
Check and revert back
Thanks and revert back
Regards,
Ayyasam
Jul 31, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500: Dodgy screen?
simply check the connections of the lcd to the board... or just tighten the screws... i had repaired a phone of that problem and this was my solutions.
May 31, 2009 | Nokia 6500 Slide Cellular Phone
Broken nokia 6500s
There is a problem with the firmware which is quite common with those phones. It will have to be taken in for update or upgrade
Apr 30, 2009 | Nokia 6500 Slide Cellular Phone
Unable to open, themes corropted.
may be your are not installing the nokia theme file
while downloading th theme from internet and copy it to phone
it is important that you download nokia compatible theme.
try again and it will work
Mar 22, 2009 | Nokia 6500 Slide Cellular Phone
Hi !!! i want to download mobile themes for nokia 6500 slide ....... please help me out .
try to download compatible themes for your mobile from zedge.net or ownskin.com and install it.
Jan 29, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500 Slide Cellular Phone Logo
172 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
