Question about Dishwashers
Hobart Commercial Dishwasher - LX40H is overheating the water when it fills up. I have checked the programing and all set points are correct. When we open the door to load the dishwasher, It steams excessively for over a minute and I can hear a noise.
  • 2 more comments
  • Ferndale Sep 05, 2009
    I don't think it is the timer because the wash and rinse cycles time correctly. The water at the end of the cycle is showing over 200 degrees and that is above the high point. Any other thoughts?
  • Ferndale Sep 06, 2009
    Is there only 1 thermostat or several?
    Thanks
    Hobart does not list a Themostat in the parts catalog. The closest thing is "Control - Temperature Limiting"
    Thanks.
  • Ferndale Sep 07, 2009
    The ebay part was for a AM14 dishwasher. The other sites you listed don't have Hobart dishwasher parts.
    Thanks for trying.
  • 3,741 Answers
You can get the thermostat here click the link directly http://cgi.ebay.com/1-new-Hobart-Dishwasher-Washer-Thermostat-103688-1_W0QQitemZ260453567990QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ca43e0df6&_trksid=p3286.c0.m14#ht_500wt_924
-- the cost is $169 -------- also you can try getting it at www.repairclinic.com or at www.shopjimmy.com or at www.partselect.com ----- this will help thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 06, 2009
  • 3,230 Answers
Well problem seems in the  Timer -
Although it's uncommon, the timer or the selector switch may be defective. If so, then it cause the dishwasher to overheat, you need to replace the Timer, because it can't be repaired.
Good Luck!!
Thanks
Posted on Sep 05, 2009
  • Mukesh Kumar Sep 05, 2009
    Ok, then the problem seems in the thermostat.
Water continues coming
Hobart ' Undercounter Dishwashers, Commercial ...
www.hobartcorp.com/.../commercial.../undercounters...
Hobart CorporationGlasswasher ... The LXe undercounter is ENERGY STAR® qualified, uses only .74 gallons of water per cycle and features new Smart Display technology to eliminate error codes. Loading... Highlights: Hobart undercounter dish machines are the most popular in the industry, keeping reputations spotless all over the world.
Advansys LXe Undercounter ' Hobart
Hobart CorporationGlasswasher ... The Hobart LXe Undercounter Dishwasher is designed to pack best-in-class cleaning power into a compact space, ... The Advansys LXe low-temp model features PuriRinse, a cold-water rinse that removes chemical residue, ...
[PDF]AM15 Technical Manual - Hobart
https://my.hobartcorp.com/kroger/.../AM15%20Technical%20Manual.pd...
Steam Booster, if used based on 20 PSI steam - 20 PSI water flowing. 130°F entering.... DRAIN AND OVERFLOW: Large bell type automatic overflow and drain ...
[PDF]Glass- and dishwashers - Hobart
Dec 08, 2015 | Hobart Undercounter Glasswasher w/Chemical...
My hobart underbench dishwsaher will not fill or heat
Sound like the inlet water valve is out. So with no water it doesn't sense water to heat.
Nov 30, 2014 | Hobart Dishwashers
How Do I fill the dishwasher with water to first start it
Close the front access door and turn on the power switch. It should automatically fill.
Oct 02, 2014 | Hobart C44a Commercial Dishwasher
Hobart AM-14 water temperature not maintained
Hobart AM-14 will wash and rinse in manual, but not in automatic
Oct 01, 2009 | Hobart AM14-253 Free-standing Dishwasher
Temp. too hot
First off, the temp adjustment can only be made by a trained service tech, since the dishwasher will need to be reprogrammed to allow for a lower temperature in the rinse cycle but still have the higher temp needed in the wash cycle. Also, since any change in the water temp settings will require a longer wash and rinse cycle to be programmed into the unit.
Of course, you could simply lower the water temp on the water heater that supplies water to this unit, but you'd have lower temp water elsewhere and likely get cited at the next heatlh department inspection on that issue.
Since this is a commercial dishwasher, you might want to reconsider lowering the temp, since health codes and standards for commercial establishments require a MINIMUM water temperarture of 185 degrees F (85 degrees C) for proper operation and to get all the crud off the dishes, etc.
Note, the manufacturer sets these units to the higher temp, 203 degree F (95 degree C) knowing that the water will cool down quickly once the wash cycle starts and the water contacts the dishes, etc. That is also why these units have a added heater element, to help keep the water at the correct temperature needed to both clean AND sanitize the dishes, according to established health standards.
If you really want to change the water temp settings, contact your Hobart service rep and explain the reason you want it lower and see what they say.
Hope you found this very helpful and best regards!
Aug 19, 2009 | Hobart SR24-H Built-in Dishwasher
Need to hook up the small pipes for sanitazing agent
The other pipe is for detergent.Any other questions let me know i'm a hobart tech.
Apr 12, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
381 people viewed this question
Top Dishwashers Experts
Owen Barnes
