Question about IOGear Computers & Internet
I have the wireless adapter GBU421. It won't pair with my phone and says it needs a passwordkey. Its says put in any 4 digits but it still doesn't work
  • 497 Answers
Try with 0000 (four zero) or 1234.
Good Luck!!!!!!!!!!!!!!
Posted on Sep 09, 2009
Cant pair my iPhone with jabra sp5050
forget the headset
turn bluetooth off
turn the headset device off
reboot phone.
try again
Mar 04, 2014 | Jabra A320s Bluetooth Wireless Adapter
D-link dwl-122 usb adapter won't see wireless networks. power light on D-link is on, "link" light is blinking. Trying to use with Windows XP
Try resetting the router. Sometimes they stop broadcasting the SSID and need to be reset.
Let me know if that doesn't work.
Jul 01, 2011 | D-Link AirPlus G DWL-G122 802.11g/b...
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
Won't install
As of this date, there is no Windows 7 driver available for the F8T016. You may want to consider buying a new Bluetooth adapter.
I bought an Iogear Bluetooth 2.0 USB Micro Adapter, model GBU421, which installed flawlessly and automatically in Windows 7.
Apr 06, 2010 | Belkin Mini Bluetooth Adapter (F8T016-KDK)
Where can you buy a replacement usb adapter for a microsoft wireless desktop mouse and keyboard 5000
If this is a bluetooth mouse and keyboard, just exactly what I'm reading and your computer does not have bluetooth built in then this is what you need to buy.
http://www.amazon.com/IOGear-Bluetooth-Micro-Adapter-GBU421/dp/B0018O9JIG/ref=dp_cp_ob_e_title_1
You can get this at your local BestBuys or online.
Don't forget to vote for me, and give me a good rating.
Mar 25, 2010 | Microsoft Wireless Laser Mouse 5000
Backbeat 903 headphones won't pair with Windows 7 64-bit laptop
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/ or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
Jan 28, 2010 | Altec Lansing BackBeat Plus Mobile ...
I need a vista compatible driver for an IOgear gbu311 bluetooth wireless adapter
GBU311 does not have a Vista driver. Because it could only support the Win 2000, Win ME, 98SE, and XP. It does not support Win Vista and later versions.
If you wish to have a Bluetooth adapter that is compatible with Vista and Windows 7, you need to have the GBU421 Bluetooth 2.1 USB Micro Adapter. Here, check the link:
Thank you and good luck!
Sep 28, 2009 | IOGear GBU311 Bluetooth Wireless Adapter
Troy Windconnect printserver has stopped working
Due to tolerances in manufacturing, some Bluetooth-adapters/receivers do not stick to the Bluetooth-standards exactly. If this only applies for one adapter/receiver in a pair everything works fine nevertheless. But if both do not stick to the standard, they might not be able to work together, although both would work with a standard-conform third one.
Before your mainboard was replaced, only your printserver was not exactly standard-conform. Now with a new mainboard (and therfore a new Bluetooth-adapter on it) just by accident your Bluetooth-adapter does not confirm to the standard, too.
If all this is right in your case, the solution would be to buy a Bluetooth-usb-dongle for your notebook and use this instead of the built-in Bluetooth-adapter of your notebook. If this new Bluetooth-usb-dongle confirms to the Bluetooth-standards better than your built-in adapter, this might cure the problem. Since such a Bluetooth-usb-dongle only costs about 10 Dollars, it might be worth a try.
Greetings, Michael
Feb 23, 2009 | Troy WindConnect With WindPort PC Card...
Open Questions:
Computers & Internet Logo
446 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
