Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
I have a Raypac C155A LP spa heater. won't light
I have a Raypac C155A LP spa heater. Approx 18 years old. MY pilot will light and stay lit. The wires from the pilot gen are very rusty. The heater will not turn on. I think I need to replace the Pilot gen. What do you think?
  • 366 Answers
I would agree with you. The pilot generator has probably degraded over the years and is only proving enough millivolts to power the pilot but not enough to run the gas valve for your main burners.
Replacing the pilot generator, preferably the entire pilot assembly, will fix the problem.
Posted on Sep 16, 2009
Pilot light wont stay lit once button is released unit is about 11 years old
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Dec 28, 2015 | Bosch & Tankless LP Hot Water Heater
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
The heat wont turn on and pilot does not stay lit
If this is a M/V heater you must have at least 400mv/dc to hold the pilot valve open. Check to make sure that the pilot is lighting, then hold the pilot valve down for about a minute. If the the pilot goes out you need to see what the m/v reading is. Chances are you have a bad pilot or gen. Replace.
Mar 06, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Pool heater pilot works but no heater
make sure filter is clean, make sure filter is at 10-18 psi , also post if electronic or millivolt heater
Jun 16, 2009 | Pool & Spa
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
388 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
