Question about Car Audio & Video
My amp is not working! i have a live from battery and a good earth,but still nothing,does it need to be earthed to back of head unit?
  • 15,935 Answers
Do you have the remote turn-on lead hooked up?
There should be 3 wires on the power side of the amplifier.
Ground - to the car chassis
Power - to the car battery
Remote - to the remote turn on lead from the head unit. (this emits a 12V signal to a relay inside the amplifier for it to turn on when the radio does)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 05, 2009
Testimonial: "thank you very helpfull :->"
    Guru:
  • 1,326 Answers
I didn't hear you mention a remote wire? If you have a good positive and ground then should be good to go. The remote wire tells the amp to turn on/off with the ignition or with the radio depending on where you wire it to. Most times the remote wire on your aftermarket radio (small thin wire usually blue) is connected to the remote line of your amp. There is none on a factory radio. If you have a factory radio you can run the remote from your amp to the radio fuse on your car and it will turn on/off with the ignition of your car. You can test the amp first by runinng the power wire on the amp directly to the remote terminal, it should light up. Do not leave it this way as the amp will stay on and will drain your battery..
Posted on Sep 06, 2009
Yeah I had the same problem, I hooked it all up right but the protect light wouldnt go off, I kept wondering why. The battery was to week so the green power light wouldnt go on.
But my problem is that I have this buzzing or humming noise to whatever I hooked up my amplifier up to? How do I get the buzzng noise to stop?
Posted on Feb 21, 2010
I have a 250 honda oddessy can not get coil to fire got two wires coming out magneto both hot and got motor and coil both graned but no fire with ether wire boght new coil still nothing was runing fine...
Hi,just a thought,first see if there is a fuse on the live battery connection and test to see if it is fulty,if not then if the part you painted is where the coil is tied to then it could be a bad earth,but I think you should try to trace back where you started,start checking from battery there has to be power to the coil for it to work,try running a wire from earth of battery to earth of coil and check for power,if no power then attach another wire to live of batteryannd live of coil if live then thats where problem will be.hope this was some help.
Dec 24, 2014 | Motorcycles
How do I set my amp I have a 500 jl mono amp and a 8" micro sub
Earth to the back light bracket bolt.
phono & remote cables to the head unit.
speaker + & - to the sub.
Live power input wire straight to the + terminal on the battery
Aug 15, 2014 | Car Audio & Video
I have a GULF CAR THAT I AM TRYING TO WIRE FOR LIGHTS head lights brake lights @ tail lights
Ok that's a pretty easy one.. What you need to do is make a wiring harness first.. you require TWO wires for each light... ONE of these wires will be a "Common" IF you have a METAL chassis, then you may use this as the "Other" Wire, the negative, or Earth. All wires are going back to the Battery... Or a connection block nearby... wire all lights, etc, from the POSITIVE of the battery, to the Switch, from the switch to the light.. and then back via the "Common" to NEGATIVE, terminal or Earth.
Simply do each as an individual circuit... use good quality 10 - 20 Amp suitable stranded wire, RED & BLACK, RED for Positive, BLACK, for Negative. use Bulb holders, 20 Amp switches.
Have a FUSE or a Circuit Breaker in EACH circuit wire.. OK, so we wire From Plus on the battery, (Usually we have a multi-terminal insulated connector mounted where we terminate each positive wire, to feed out to each circuit) it then goes from the Positive, to the Fuse/CB, from, the other side of the Fuse/CB, on to the say, a Switch, Terminal, & then, from the other Terminal of the Normally OPEN switch, to one side of the Bulb (Holder) the "Other" side of the Bulb, goes back to the negative or Earth. ALL Earths go together, and are Common. ONLY the Positive or RED is LIVE.
We always switch the Live wire. Brake lights are usually wired in series. Remember one can obtain Dual Filament bulbs, for Indicator and brake lights.
Simply duplicate this for each circuit, and then we tape them all together in a "Harness" and route the harness where-ever is suitable for it to go.
Usually we run a heavy wire from the Plus battery terminal, to our multiway connector for our Positive "Outlet". to connect to the individual circuits.
Draw out a circuit FIRST for EACH light and any switch, and then follow the diagram.
Jun 14, 2011 | Siren ,for Car,gulf Cart,rv 905
There is no power to the radio it does nothing will not light up.
Check the fuse on the back of the stereo, usually 25amp blade fuse, and there could be another near the other end of the power lead. If that doesn't work, run a new earth lead (black on the back of the stereo, to any earthed metal), power lead (yellow, to a good positive terminal or to the battery), accessory lead (red, to the ignition switch or a fuse associated with it). If neither of these work then your head unit will more than likely be dead or have a security feature stopping it from powering up.
Jan 11, 2011 | Car Audio & Video
How to wire sreaker system
this is the same as a home speaker system, if installing an amp and sub you need to make sure you have a pre-out on your cd/tape/radio head unit. this will look like a red and white hole usally with l and r on it,
you will need to run a male phono to phono lead from the head unit to the amp, You will also need to run a fused live 12v from your battery to the amp live input (red wire) and a remote (usally blue) from your head unit to the amp (make sure you run the live ond remote on opisite sides of the car to the phonos as they can interfere with each other).
you also need to run an earth/ground to your amp, this must not be to long, i normaly just un srew a screw in the boot and connect it to that.
once this is done you can wire up your sub to the amp making sure to match - to - and + to plus.
hope this helps
Jan 02, 2011 | Car Audio & Video
Cant find hand brake wire for clarion dvd head unit model no. vrx486vd well i cant get video to work earthed the grass green wire and nothing please help!!
i have the same model its the green wire next to the earth wire bottom row make sure u earth it otherwise the unit can be frustrating at times!!!!
Sep 06, 2010 | Clarion VRX755VD Car DVD Player
FITTED REPLACMENT POWER ARIAL TO SHOGUN IT WORKS BUT RETRACTS WHEN I SEARCH FOR STATIONS. OLD UNIT HAD 5 WIRES BUT NEW HAS ONLY 3. I PUT LIVE TO BATTERY AND SWITCHED LIVE TO SWITCH WIRE EARTH TO BODY.
yeah this happened to me but sorted it. live to battery for the blue find power anntena wire on back of stereo [ usually blue] connect, black wire earth to the body. the 2 wires are for the half mast switch - just blank them off.
Aug 07, 2010 | 1999 Mitsubishi Montero
I really have two questons. the first is that the light of the panel on my stereo is always on. whats that from? the other is that i have a sound system in my car. i know its the head unit. when ever my...
Hi There. This may be line noise.
Check that your head unit and amplifiers etc are all earthed to the same earth. ie: If connected to the battery earth then connect all earths to battery, or if connected to body earth then connect all to body earth.
Another thing is to check that your RCA Cable or interconnects are not running with your power wires. This can induce line noise.
If all is correct then get yourself a noise suppressor or a ground loop isolator.
Hope this helps
Aug 19, 2009 | Virtual Reality VR3 Car Amp
When i turn my radio on my sub makes sounds and backfeeds even when the engine is off. i tried switching the remote wire from my radio to different wires but it either doesn't work or still makes the...
Hi It will be an earth problem or even if your speaker wires or rca leads are running along side any power wires from your car, Find the most chunky metal part of your dash, clear all paint away, make the earth wire from your head unit less than 1 foot from you head unit and make sure its not conected to any earth that run back to your cars power system. if it still makes the noise make sure your speaker wires or rca leads are not running along the cars power wire they will pick up feed from them. make sure your head unit is not earthed to your cars arial silly as it sounds the arial plug in is one of your main earths to your cars audio system. hope you work it out
May 06, 2009 | Car Audio & Video
The power light flicking on and off.
sounds like either a bad earth or a bad remote signal.
check the earth cable for continuity - make sure that it has a good earth to the chassis of the car.
also check the remote signal cable that runs from the back of the head unit to the amp ~(use multi meter to check continuity).
Apr 09, 2009 | Pioneer GM-X334 Car Audio Amplifier
Car Audio & Video Logo
767 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
