I have a weather king legacy furnace the a/c
I have a weather king legacy furnace the a/c compressor keeps runing even with the thermostate removed and the blower motor does not run
  • 128 Answers
Means the compressor is directly energised may be some one tried to repair but he jumped the thermostat.
Posted on Sep 05, 2009
If anyone has any knowledge on furnaces gas let me know mine keeps cutting the flame when the blower motor comes on idk what to try and fix but don't really want to call someone to fix it
gas and boilers if not fixed correctly generally result in explosions
Gas is not a diy item so get in a professional gas fitter to fix the fault and be safe
Oct 28, 2017 | Weather King Heating & Cooling
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
FAN WILL RUN BUT COMPRESSOR COMES ON WHEN IT WANTS TOO. WEATHER KING 12AJA4201 PS LAYED OFF OVER A YEAR PAYMENT COULD BE A PROBLEM YOUR HELP WOULD BE A BLESSING
weather kings are like that (junk),i install 8 or more a week on new houses,they all do that.yours is a 3.5 ton which is what i set.if the t-stat calles for a/c within 5 mins of it turning off after a cycle,the compressor has a protection built in which keeps the compressor from coming right back on when it just stoped.they say its to keep it from burning up from going on and off alot.
Sep 24, 2010 | Weather King 12AJA6001AH Air Conditioner
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
Weather King Acclaim 2 Gas furnace efilters
If your furnace is easily accessed in the basement or a closet etc. then likely the filters are located either in the bloer compaertment (the small panel on the furnace) or in the ductwork attached to the furnace. There should be a removable cover. The size varies dedending on the size of your system. When you remove the old one it should be printed on it or you can measure it.
If your furnace is in the attic or a crawl space then you probably have filter grill(s) in your return air. Usually centrally located in the home.
Filters should be changed as needed depending on how you use your system but usually every 30-90 days.
Jan 17, 2009 | Weather King 12AJA4801AH Air Conditioner
Not Cooling
Yes, the compressor might not be running. Possibly a bad run capacitor or maybe burnt wires on the contactor or compressor flags.
Oct 26, 2007 | Weather King 10AJA3601AH Air Conditioner
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
