Question about Dell Dimension 5100 (D51L1) PC Desktop
Puter has power but on switch just flashes
Light on m/board is but nothing is firing up , tyhe on switch just flashes on/off
  • 558 Answers
Try this unplug the computer hold down the power button for twenty seconds try again, no goif the light in question goes amber at any stage the power supply is bad.
Good Luck
Posted on Sep 05, 2009
The power standby light flashes 3 times. checked the lamp door access switch, is ok what next?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. You might have replaced the bulb. But, have checked the ballast? Checked whether ballast board get voltage from the power board? Check these.
Jun 08, 2014 | Televison & Video
How to determine if power board on emerson tv model lc320em1 is shot
The power supply regulator board to your TV is now working fine, and has no problems at all, as, there is standby light. Check all the other voltages comes out from the power board, to main board. If all of it found OK, the fault should be at its main board.
About blinking of standby/power light;
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Emerson Lc320em1 TV
When i plug in the heater and try to start it nothing happens. the light is on at the switch and the ac outlet works. i tried jumping the reset button and the limit switch. and nothing. i have power...
Is the green light on on the circuit board .if not then you might have a blown fuse ,if yes the try jumping the heat from the board it self and you do that by putting a jumper from R to W
This is where the thermostat wire is .if unit works then you have a bad thermostat
Dec 06, 2017 | Mr. Heater MH175KT Open Flame Utility
Power light inside ?sound screen comes on but nothing happens when standby/power switch is punched light begins to flash on and off but still nothing happens--no sound, no picture, no static, nothing. Is...
Yes,the tv power supply board probably have dead components,likely a couples of capacitors on the power supply board have gases leakages,it dead,not funsctions any more.Take it to the tv shop pay for trouble & repair for you,this tv name are spacially made for and sell by the Target stores only.Very limited whole board parts,available on the net to buy.
Jun 24, 2010 | TruTech PLV1615T 15 in. LCD Television
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Will not power up. Light just flashes
In order to prevent very bad things from happening (e.g. sparks, smoke, fire), most TVs do an internal self-test and will not apply full power if the test fails. They typically flash the power light to let you know that they are refusing to start.
In your case, some internal component has failed. On most LCD TVs there is a power supply board, a main board, one or two inverter-boards, and a LCD controller board. Power supply problems are very common on all models.
Oct 16, 2009 | ViewSonic N2630w 26 in. LCD TV
U-Line Model ULN-CLR60B-00
call 1-800-779-2547, U-Line's tech support.
Has to be a bad a switch, wiring issue or maybe a control board. pull the service cover and see if the red light is lit on the board (or flashing). Light on (no flashing) indicates the board is powered up and no errors are occurring.
http://www.u-lineservice.com
Jun 09, 2008 | U-Line Icemaker
HP Media center 1170m
did you checked the ram just clean and fix it again. bye
Oct 01, 2007 | HP Media Center m1170n Photosmart PC...
Monitors on/off green light flashes
Try first unplugging the monitor and the computer from the wall for 12 to 24 hours. If this does not work, hook up another monitor to the puter to see if the problems with the puter or the monitor.
Sep 22, 2006 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell Dimension 5100 (D51L1) PC Desktop Logo
100 people viewed this question
Alun Cox
