Question about Craftsman Garden
The mower belt on my craftsman 917273070 keeps slipping off (ever
How do I adjust the tension on the mower belt of a craftsman mower 917273070?
4 Suggested Answers
  • 18 Answers
SOURCE: motion drive belt on craftsman riding mower
there is no adjustment..it is set by the spring that engages ur drive belt....
Posted on Sep 03, 2008
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
  • 10865 Answers
SOURCE: I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
Posted on May 20, 2009
Tensioner belt keeps slipping off front pully
Everett, Do you mean drive belt keeps coming off front pulley?
Possible causes, accumulated dirt/debris above deck or on trans axle, damage,stretched,wrong size belt, belt tensioner seized/missing spring if equipped, belt retainers/guides/keepers damaged /missing/ adjusted to far from pulley, damaged/worn pulleys, loose engine, belt way out of alignment,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Are the Causes of Belt Coming Off Riding Mower
Drive belt keeps coming off when shift into reverse
Need help with mower deck belt keeps coming off Craftsman LT2000...
belt keeps popping off
Jul 20, 2016 | Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Yth2248 loses speed on slightest grade. new drive belt not helpful
Roy if it is the correct belt and fairly new, check your manual for belt adjustment, if it shows that there is no adjustment the pulleys may be worn out, on a lot of mowers the pulleys are ware items and changed more often to correct slipping issues. The other thing to check is the belt tensioner if equipped, it could be seized, weak or missing spring or it may even be adjustable by cable end being threaded or slotted bolt holes on tensioner arm.
Drive Pulley Replacement On Craftsman Lawn Tractor
Mower Engine Pulley Replacement Craftsman Riding Lawn Mower Repair Part...
Cub Cadet LT1045 Transmission Drive Belt Replacement
husqvarna LGT24k54 drive belt install
Apr 22, 2016 | Garden
Replace belts on 917-271821
The deck has an idler pulley that keeps tension on the belt. The idler pulley is mounted on a pivoting bracket, that has a spring which provides the tension. You have to move the bracket so as to take the tension off the belt, thereby allowing you to slip the belt off the other drive pulleys
Aug 15, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My craftsman 22" self propelled
Your problem is at other end . Engagement problem is probably due to a loose belt. Make adjustment in that area of mower. GOOD LUCK.
Jun 16, 2011 | Craftsman Garden
The self-propelled mechanism on my EZ Walk Craftsman does not work. Anyone have a solution?
What you can try is to open the case surrounding the self-propelled drive and make sure that the belt has not either slipped off or has broken. Depending on the model, the case has two or four screws securing it to the frame of the mower. If the belt has slipped off, you can unscrew the tension screw and slip the belt back on and then tighten the tension screw so that there is enough tension on the belt to keep it from slipping off.
If the belt has become broken, you can purchase a new one from Lowes or Home Depot for approximately 15.00. The change out procedure is pretty straight forward and shouldn't take longer than 5-10 minutes.
If the belt is fine (not loose or broken) it could be a gear problem in the drive wheel, in that case you are in a little bit more trouble than simply replacing the belt.
Hope this information helps.
Thanks,
May 09, 2011 | Garden
HOW TO ADJUST THE CUTTING BLADE TENSION OF THE MOWER BELT.
There is no adjustment on the Craftsman mower belt tension. The tension is maintained by a spring. If the belt is to loose you either have the wrong belt or something is broken like a mandrel housing that holds the fixed pulleys in place.
Oct 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman front wheel self-propelled, push mower: belt keeps slipping off tension pin. Also, the wheels don't rotate as rapidly as when I first bought it last year.
Make sure the pulleys are aligned perfectly straight and replace the old belt with a new one. The pulleys have an allan head set screw you need to loosen to adjust the pulley.
May 03, 2009 | Garden
Garden Logo
307 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
