Question about E-Machines REXUS SPE-300 ATX 300W P4 Power Supply for eMachine computer (SPE300) Power Supply
My E machine when i turn it on it turns right back off could it be my power cord
  • 600 Answers
Could be your power cord or the power supply
Posted on Sep 08, 2009
Why wont my lg 50 plasma tv turn
Perhaps replace your power cord. Borrow power cord from repair shop. If it works it's the cord. Also if the TV is plugged into power bar make sure the power bar hasn't been inadvertently turned off.
Oct 07, 2015 | LG Televison & Video
Singer futura xl 550 power will not turn on
it's possible that the power cord has gone out
or the on and off switch
or the motor
Jan 02, 2013 | Sewing Machines
Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
Mar 29, 2012 | Janome Memory Craft 9000 Computerized...
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
My printer says its empty but it is full of paper and i can not use my machine. Also it a sheet out everytime i start it up
Hi
Start with printing a self print report:
- Load plain white paper into the tray. - Press the Setup button. - Press the right arrow to select Print Report , and then press OK . - Press the right arrow to select Self-Test Report , and then press OK . The product prints a self-test report.
Now Reset the printer:
- Press the Power button to turn on the product. - With the product turned on , disconnect the power cord from the rear of the product. - Unplug the power cord from the wall outlet. - Wait at least 15 seconds. - Plug the power cord back into the wall outlet. - Reconnect the power cord to the rear of the product. - If the product does not turn on by itself, press the Power button to turn it ON
OR
Remove the paper tray completely, and examine the paper recognition switch. There is a pressure switch that is depressed when paper is inserted into the machine. If it is broken, or there is a small piece of paper or debris blocking it, that may be your issue.
Hope this helps, p[lease let me know if any problem persists, thanks!
Aug 23, 2011 | Office Equipment & Supplies
Xerox WorkCentre C2424: turned on, runs thru tests, initializing and then shuts off and starts the cycle again. The cycle continues but never resolves.
1. Power machine off and wait until completely off. 2. unplug power cord from wall. 3. with power cord STILL DISCONNECTED turn machine on and off again. 4. WAIT 60 SECONDS 5. plug power cord back in and turn back on
If this does not resolve the issue call for service.
Hope it helps!
Feb 09, 2011 | Xerox C2424 Copier
I turned off coputer at night before sleep but in the morning on pressing kng to turn it on it did not turn on besides cord is fine and in right socket
Try turning off the power to the machine by pulling the power plug at the case back and let sit for a few moments, then reapply power. If it doesn't come back, then you may have a bad power supply which must be replaced (don't allow it to be repaired as a new unit is far cheaper than the labor costs alone). Did you try a lamp in the socket where the machine is plugged in? Hope this helps!
Mar 31, 2010 | E-Machines eMachines Desktop PC
Scanner 2 error won't allow machine to operate even after turning on/ off numerous times
turned off machine. Unplugged computer connection,disconnected power cord from source. replugged computer line, installed power cord, turned machine back on. worked..... turning on/off at switch did not work.
Sep 30, 2009 | HP Office Equipment & Supplies
Will not turn on
unplugg everything from the back of the wii and unplugg the power/ac adaptor form the wall wait 2 minutes and plugg everythnig back in.....hopefully this works for you it worked for me!!
Aug 26, 2008 | Nintendo Wii Console
E-Machines REXUS SPE-300 ATX 300W P4 Power Supply for eMachine computer (SPE300) Power Supply Logo
57 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
