Question about Hitachi 46F510 46" Projection HDTV
Hello! I have a Hitachi 46F510 TV-projection TV. It has a dark and blurry screen....HELP!!
  • 3,230 Answers
First of all take the lower back cover off the set and you will see three glass lenses, spray glass cleaner directly to a very soft cloth and clean those dirty lenses then you might want to check the mirror for dirt but on some rare cases it gets dirty and I wouldn't mess with it. if further you have the same problem means your TV has a convergence board problem which is very common with these types of TV's even with the other brands. The fix for this is by replacing two identical IC's with part# that starts with STK. But before replacing these IC's technicians check small components called resistors and pico fuses. They also check for loose or cold solder connections.
Have it checked by a qualified repairman because there are parts inside your TV that are still holding dangerous amount of voltage even if it's unplugged from the wall outlet. It will cost around $250 to $300 to fix your TV.
Thanks
Posted on Sep 05, 2009
Hitachi projection tv 46F510 picture and sub title are blurry but the colors seem ok ?
Try turning the contrast (picture) down and see if helps--if contrast is too high this will happen and be normal.
Nov 30, 2012 | Televison & Video
My hitachi 46f510 rptv has a dark and blurry picture
there is a focus setting in the back pannel you need to open the back and look inside for it
Jan 06, 2011 | Hitachi 46F510 46" Projection HDTV
My hitachi 46f510 picture is dark and blurry any suggestians
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
The hitachi 46f510 has went out of foucs how to fix it loos as if u watch through wax paper
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 27, 2010 | Hitachi 46F510 46" Projection HDTV
I have an Hitachi 46F510. The picture is blurry. Mostly when words are on the screen (i.e. the menu).
The convergence is dead.U need a convergence kit.These websites have it.Tv Repair World.com and Shopjimmy.com.Buy the kit with ur tv model and fix it.
Sep 10, 2009 | Hitachi 46F510 46" Projection HDTV
Hitachi tv problem
I'm going to say you have a VCR or something hooked up, if so turn it off and if not its probably the television companies equipment
Jul 25, 2009 | Hitachi 46F510 46" Projection HDTV
HI i have a 42" Hitachi HDTV 1080p (LCD)
Most newer Digital TV's don't display Analog signal very well. Often worse then an Analog TV. This is normal to a degree. If your Wii has component  cables, try using that. As for cable, you might get a better signal with Digital Cable.
Apr 23, 2008 | Hitachi 46F510 46" Projection HDTV
Old hitachi
the coolant most likely needs changing in the CRTs. Another possibilty is the mirror has become dull. use a damp soft cloth to clean the mirror then dry also clean the CRT lenses . Dont use windex. You will be amazed the difference just polishing the mirror can make in picture quality. Looking into the CRT lenses while they are on will tell you if any groth are present in the CRT coolant chambers.
Jan 20, 2008 | Hitachi 46F510 46" Projection HDTV
Blurry picture when it is dark screen(black color)
Did you get a solution to your blurry tv problem. I'm having the same problem with my Hitachi 42" rear projection.
Nov 17, 2007 | Toshiba 65H93 65" Rear Projection...
Dark , blurry picture
MTNESTR, My guess would be the FBT loc.TH01(flyback transformer) Hitachi p/n#BW03004 which would be far less expensive than replacing the entire deflection board... A shop could ring test the FBT to confirm the failure. I do know the FBT in this unit has an internal resistor that is prone to failure. It is in-line with the focus block and if it's open it would explain the blur and lack of screen voltage to light the crts properly. The deflection board is about $290-$350 plus shipping and a FBT is somewhere between $60 - $90 depending on the supplier. Hope this helps! Bill
Jun 04, 2007 | Hitachi 46F510 46" Projection HDTV
Hitachi 46F510 46" Projection HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
