Question about Peg Perego Vespa Scooter
Vespa Starts and Dies Changed Fuel and Tried to adjust the Carb
Can,t get the engine gooing after storring over winter. Air filter is clean ,Spark Plug O.K., Jets Are O.k., May be I can't Adjust Carb right or I'm Missing Something. I have aVespa ET2.
Thanks
  • 32 Answers
SOURCE: Fuel Starvation Problem
Try taking off the fuel line from the tank to the carb and blowing through it
Posted on Aug 03, 2009
  • 32 Answers
SOURCE: trouble starting my vespa
check your takn and clean your fuel and air filter and check the fuel line from the tank to the carb and blow it out, 1 of these should help.
  • 87 Answers
SOURCE: vespa starting problem[smallframe douglas 90cc]
did ya rebuild the carb or not sounds like the carb got ear wax in it
Posted on Aug 04, 2009
  • 16 Answers
SOURCE: turn signal replacement on vespa ET2
Front bulbs are accessed through the glove compartment, remove the round caps and you can get at the bolbs from behind
For the rear bulbs you need to remove tha full indicator unit by unscrewing the screw and taking the unit out. the bulb is accessed from behind
Posted on Aug 23, 2009
  • 85 Answers
SOURCE: hey there, the time clock on the seedometer of my
http://www.modernvespa.com/forum/topic8062
Posted on Oct 03, 2009
I have a Troy Bilt trimmer model TB675EC...4 cycle engine. Problem that has arisen is that it dies at high speed and under load. Starts up and runs at idle well.
Fuel starved, carb should have an idle adjustment which sounds like it is fine. Look for the second adjustment
Jul 17, 2017 | Troy Garden
Vespa et4 125 fuel starvation? Cuts out on me... Help?
Check the main jet is set up correctly. Make sure there is plenty of fuel in the float chamber, if not check the fuel line again. There should be a good amount of petrol flowing from the carb feed pipe with the fuel tap on. It should fill a pint container fairly quickly.
Apr 24, 2017 | Vespa Motorcycles
Mtd yardworks walk behind starts then idles down shuts off after 20 seconds whats wromg
Usually when a mower dies, it is a fuel delivery problem. Have you changed the filter? Is the gas fresh. Also has the air filter and spark plug been changed recently? the Carburetor may need to cleaned. Take the air cleaner off and spray some carb cleaner in the throat of the carb. Also, take about 1/3 bottle of carb/fuel system cleaner and add it to the gas in the tank.. For the new mower engines, there is no fine-tune adjustments on the carburetor. Also clean the exterior of the carb with carb spray.
May 20, 2014 | Mtd Garden
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
21cc starts then dies. I cleaned the tank, replaced fuel line, fuel filter, and cleaned carb with carb spray. However, it still dies after a few seconds from starting. Recommendations? Thanks, - Troy
The fact that it starts is a very good sign that there is not a major problem. Here are some random suggestions from my vast experience with small engines, start with the simple ones, and work your way towards the more difficult/costly: Air filter, be sure choke is working properly, clean carb with compressed air, replace internal parts in carb, gas cap, leaky primer bulb, clogged spark screen in exaust, carbon build up in exaust port/muffler, idle/mixture screw adjustment, faulty plug wire, short in kill switch, bad fuel or mixture. Also, when you say, or I say clean the carb, I mean the INSIDE of the carb, not the outside. I hope this helps, keep me posted as to what the problem was!
Oct 15, 2011 | Garden
Hi i have a t5 millenium it is fitted with a scorpion exhaust and a 115 main jet,the bike starts ok first kick with the choke out once started choke goes straight back in.when i ride it from cold i can not...
Hi, Mike_hall558 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
t5 only running with choke out vespa org uk
How To Repair Snow Blower Carb Engine Only Runs with Choke
http://www.pcimmesir.com/vespa-px-125-e-service-manual.pdf
PartsSchematicP PX PXE STELLA 125 150 200
VESPA PX 125 T5 Operation And Maintenance
Apr 19, 2017 | Vespa Motorcycles
Saw starts then dies. Changed fuel ine soaked carb
Check the fuel filter, air cleaner and muffler for plugging. Was the carburetor disassembled when soaked and did you use compressed air to blow out all passages? If the carburetor jet screws have been moved, preset them as follows: Turn both H and L screws CW to stops (lightly), then back out CCW each screw 1-1/2 turns. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine speeds up somewhat but 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that chain stops turning, but the engine continues to run. Hope this helps!
Mar 30, 2010 | Garden
Jul 12, 2009 | Peg Perego Vespa Scooter
Trouble starting my vespa
Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Apr 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Peg Perego Vespa Scooter Logo
164 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
