Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
Sears power washer will not produce pressure - Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
View owner Manuel for Sears power washer mod.# 580.762600
Sears is great for manuals. Go to web site and search your model.
Sep 17, 2014 | Garden
Burned through the hose, repairs?
With the high pressure that these units produce, I would recommend replacing the hose instead of repair just for a simple matter of safety.
Feb 12, 2013 | Craftsman 2700 PSI Briggs Stratton...
I have a Honda XR2600 pressure washer. When the wand trigger is pulled, the throttle does not open, the RMD just drops. If i manually open the throttle, it works fine.
Your engine produces max horsepower at 3600 rpm. The engine throttle should be set to max before you pull trigger. Pressure washes generally do not have automatic throttle. You do not have to use max power, but enough power to keep the engine running when trigger is pulled. You washer will actually last longer if you only use about 75% of rated capacity. Good luck
Oct 15, 2011 | Karcher 2500 PSI Pressure Washer
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
How to repair chemical pickup pump
Make sure that you have adjusted the nozzle on the end of the washer so that it produces low pressure as this is the only way it will ****.
Apr 12, 2010 | Karcher K2.26 Electric Power Washer
My Sears Craftsman power washer won't start. I checked gas and oil. Levels are okay.
Have a 7.0 gas water pressure washer and it won't start. Replaced the spark plug checked the fly wheel and it still won't start.
Sep 02, 2009 | Garden
Jet of water from a bent-elbow fitting when pulling gun trigger
the elbow may be cract insight, try to open it, but first diskonect it from power jet.
Jul 15, 2009 | Karcher 2500 PSI Pressure Washer
Whirlpool Cabrio Washer Error message code F1
The following list of codes indicates a possible electronics communication problem with the washer:
Cabrio washer - F1, F2, F40, F41, F42, F50, F51, F52, F53, F54, F72
To remove the error display, press Pause/Cancel twice.
PLACEHOLDER FOR ART
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Please do not forget to rate and comment about your experience with fixya today.
Aug 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
142 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
