Question about Sony FD Trinitron KD-34XBR960 34" TV
We have a SONY kd-34XBR960 I turned it off and
We have a SONY kd-34XBR960 I turned it off and now it will not come back on. It is blinking 7 times . We normally leave the TV on all the time but thought I would cut back on electric bill.
  • 178 Answers
Turning your tv off did not cause this issue, so don't blame yourself for that. A 6 or 7 blink shutdown is because one of the two switch mode power supply control ic's have failed. the part number on them is mcz3001. They are located on the "D" baord, i don't recommend replacing this yourself because even with a tv unplugged from the wall high voltages still exist in the set.
A repairman may preform one of the two following things, he may change the whole D board or he may replace the individual components. The repair will cost around $200 if they replace the components, and if they replace the board it will cost more.
Posted on Sep 05, 2009
Engineer seeks help with no-picture, no-sound, normal standby blinking
Could just be a power issue. I have not done much with CRT televisions except smash them to bits. I would open it up and try and look for anything obvious. Since it is taking so long to come on, I am wandering if there is a cap that is failing. It will be hard to know if there is no visual evidence of failure, and the only true way to measure is with an ESR meter.
Apr 24, 2013 | Sony Fd Trinitron Wega Kd-34xbr960 34 in....
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
I have a Sony KD-34XBR960 that sound like it is
phillips has the same problem but if your tv actually turns on it could be a short or just a fuse sonys a better tv than phillips should be an easy fix call a repir guy going price for that problem is 75.00 dont pay any more than that. the economy is bad everyone needs the work be smart. make sure if you say yes to the work that the repair guy will waive the consultaion cost of usually 35 to 75 dollars, if you chose to have the work done.
Jun 02, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
Stanby lights blinks 6 times pauses then 6 x and pauses
Good day.
try to check for loose contacts along the power supply section then resolder. Also, check for shorted vertical IC.
Chris
Nov 08, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
Dear Sir, Is a 250.00 sony KD-34xbr960 a good buy(mfg date 6-05)? This unit is a sony "factory remanufacture" Thank you Arthur Dodge
Arthur,
Thats is a good deal, these sets last a long time and are very solid. I would have no problem paying 250 for that unit
Jul 16, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
TV will not turn on
Sounds like the thermal fuse has gone bad. Sony part# 191002393. Very enexpensive part. It is located near the lamp housing from the back of the set. Once you have the new part in your hand, it will be easy to find.
Jun 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Our set turns itself off by itself. Prior to this happening, it goes to a green screen. It usually happens after the set has been on for a couple of hours. We bought the set in April, 2004 and the warrantly has now expired. The longer we keep the set on, the more it turns itself off. Is this a tuner, on/off problem or the tube? Any estimates for repair?
Jun 15, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
Sony FD Trinitron KD-34XBR960 34" TV Logo
1,074 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
