Question about Hitachi 50UX57B 50" Rear Projection Television
Hitachi 50ux57B Hello,my tv works fine ,except the display no longer works:can't see the menu,channel #, volume bar--anything that gets displayed on the screen-I did try pushing the Menu button on the tv and still nothing.
  • nealll Dec 09, 2007
    Thank you very much! It worked!
    President:
  • 4,402 Answers
First thing i would do is unplug it for a couple of hours then plug it back in.
Posted on Dec 08, 2007
My Toshiba 36AF43 won't get any channels with converter box or anntenna
  • Connect the antenna to the antenna input of the converter
  • Connect the R-W-Y outputs of the converter to the corresponding inputs on the rear of your Toshiba TV.
  • Turn both units on. You should see a converter menu displayed on the TV screen.
  • Select channel scan on the converter. You should see a progress bar displayed on the TV as channels are detected.
  • Scanning should finish by displaying one of the scanned channels.
Dec 08, 2017 | Toshiba 36AF43 36" TV
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 2
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
Feb 01, 2011 | Samsung TXD1972 19" TV
Toshiba 46HM95 wont display 720p from dtv antenna other tv works
lets start with the easiest first.does your tv in the menu option offer an input output source like 720p or 480p?on my set i can change to any format.maybe yours does too.let me know and we go from there.
Mar 04, 2010 | Toshiba 42H81 42" Rear Projection...
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Hitachi volume bar always on, remote doesn't work
you can start by opening the front panel and check if the control board (with channel ,volume ) is correctly fixed or need to be solded.
the service manual is here in 6 parts and for free...:
http://www.eserviceinfo.com/downloadsm/31328/Hitachi_43FDX10B.html
cheers
Dec 21, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi TV screen adjustment
in the menu , the display or video settings should have different video display settings such as 16:9 , 1:1 , 14:9 ect... these will change the video display to different sizes
Oct 09, 2008 | Hitachi 50UX57B 50" Rear Projection...
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
Hitachi 50UX57B 50" Rear Projection Television Logo
52 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
