Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
When I engage the PTO, the blades don't egage.
I can hear the it trying to egage but the blades or the belt don't move.
  • 138 Answers
The first thing we need to to do is verify that there is adequate /(power 12 vdc) going to the electric clutch, you can do this by unplugging the clutch and check both wires 1 should have 12 volts and the other wire shoud read infinity to ground if this checks out replace the clutch, if you dont have 12vdc to the wire replace the relay
Posted on Sep 07, 2009
  • Jim Clayton
    Jim Clayton Apr 07, 2014
    When I pull the PTO, I hear a click
John Deere eztrak mower went over a rock today and now the mower won't engage
hmm strange are the belts driving the blades ok if so then the PTO could be damaged but if there's no sign of damage it maybe a bit frozen up/locked up have the engien off but turn the key on and engage the PTO switch and manually turn the PTO (not by the blades please....dont want to have your hand taken off) turn by the PTO itself and if you hear any clicking sound disengage the PTO and engage a few times to ensure your hearing the clicking sound of the PTO turning on and off and it should be back to normal also check any connections going to the PTO before doing the manual work of repairing the PTO
Apr 22, 2017 | John Deere Garden
I have a 52" Husqvarna LGT 2654 riding lawn mower and when I engage the blades, the belt does not turn the pulley system. What could be causing this, the pulley idlers, or the belt?
depending on the age of the machine, there could be several possibilities
1-- belts are not tight enough--- belt tension system is not correct, wrong length belts
2--bearings for the shafts for the blades are rusted up and seized - preventing the blades from moving--- switch the machine off , disengage the belt drive and see if you can turn the blades by hand
3--- if you have an electric pto system to drive the belts to the blades then that system is not getting full power to engage the PTO or the clutch is not working--worn facings
take it to a service dealer and have a proper diagnosis done
May 09, 2016 | Husqvarna Garden
When running the mower, it shuts off immediately when trying to engage blades(pto)
Hi Digger:
I've two possibles come to mind for you to check.
1) Engine OFF - Make sure that all of the blades and pulleys can turn freely.
2) Engine OFF - Double check belt routing. Move engage lever ON/Off and look at what movement happens. It may be that the belt is on the wrong side af a mounting flange and binds when engaged.
Cheerfuls.
Sep 18, 2015 | Garden
Blades not engaging
Blade belt is basically driven by a electro magnet check for power and ground at the wiring coming out of the pulley assembly at bottom of motor
Aug 04, 2015 | Garden
Why blades won't engage on my mtd 54" rider?
Broken or loose PTO belt, or PTO shifter linkage.
Aug 10, 2014 | MTX Car Audio & Video
Timecutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, yiu can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
May 12, 2014 | Toro TimeCutter SS5000 zero turn mower
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Hi I have the YTH2348, the problem i'm having is i'm getting a bearing sounding squeal when i have the blade clutch engaged. I noticed before it starts to squeal I'll hear a like loud click and...
if its an elect pto then it sounds like its in the workings of the pto pully
also if its a manual lever that you move to engage the belt, it could be the pully that tightens up the belt and turns the blades, most of the pullies are greaseless and prettymuch throw away
Jul 25, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
When I pull up on the PTO lever the blades don't
You have a belt adjustment problem, or a broken belt. Look at the area where the belts are, you will probably see problem immediately. Good Luck
Jun 12, 2011 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Replaced belt for mower thought i put it all back correctly blades engage when key is turned engage lever to off what did i do wrong
If you look at the motor pulley area, there should be two different pulleys with a PTO clutch between them. The PTO clutch has wires going to it, because it is operated electrically by the blade engage switch.
It sounds like you could have accidentally put the mower deck belt onto the main drive pulley (which turns all the time) rather than the pulley that is farther out from the engine, which only turns when the engage the blade switch. If so, just loosen the mower belt and move it to the right pulley.
Jun 09, 2010 | Garden
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
437 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
