An orange light comes up on my adapter - Computers & Internet
  • 558 Answers
Can you go to the internet or not,here is a quick test to see if you have a ip address,check your network properties,you basically looking for the ip address which should start 192.169.1.1. If you do you are receiving a ip address from whatsoever you are connected,if not and you see 169.2.2.1,windows has assign a ip address to you, therefore you might want to swap cables first.So here is another option unplug the device you are connected to count to ten plug itin let it come up restart your computer.now if you can go to the internet and the light on the network card is orange i wouln't worry about it.
Good luck
Posted on Sep 05, 2009
Orange light on and it wont turn on
Is it an orange battery indicator? If it is, it means the AC adapter is charging the battery. Please charge the battery for 1 hour before you press the power button again.
Mar 02, 2014 | Dell Latitude E5500 Laptop
Orange battery light comes on and the computer says low battery. Computer does not work even when plugged in to wall outlet. I don't think it is the adapter because blue ring on plug in to the com
Diagonizing and analysing this problem, it's obvious that the orange light means battery low.
Have u ever tried charging the laptop with another charger/adapter?
If no try it because some adapters/chargers don't work with some laptops. Also be careful to use the recommended adapter, some can spoil the laptop's panel.
Jul 23, 2012 | Dell Studio 15 Laptop
My Ac Adapter i think is broken and my Xbox wont turn on but the AC adapter has a orange light that when i unplug it the orange light still does not go off.
Hi if the main brick has got an orange light then this is telling you the mains lead is working so try doing the following
1 unplug all leads from back of xbox and turn the power brick off at mains
2 plug the power lead back into the xbox, now when you push it in and it stops try pushing it in a little bit further usually they just dont push in far enough and it can be quite tight so make sure you are pushing it in hard enough,
3 now plug the video lead in and try switching it on,
keep an eye on the orange light whilst you switch it on if it comes on then it should continue to work if it dont come on watch the orange light and see it if changes color at the same time your switching it on, it will either flash green or red just once before going back to orange.
let me know what happens ok
Nov 28, 2010 | Microsoft Xbox 360 Console
Changed the DC adapter plug it in orange light Problem with the Acer Aspire 5500 5532 5535 Laptop Computer (AS55702609RTL) PC Notebook changed the DC adapter plug it in orange light comes on charging I try...
If after the replacing the AC adapter the problem still persists , the power board on the motherboard has gone bad. The same can be repaired, but would require you to take the system in for repairs. if the system is under warranty then the best thing to do is get the motherboard replaced.
Thanks
proton
Nov 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
When i power on my ds lite my green light turns on then turns rite bcak off and when I attach the charger it does the same thing.... What/s wrong with it?
Does the orange light come on when you plug it in? If it does, then it is a failure of either the DS's BIOS or its Memory. If the orange light doesn't come on, then the AC adapter is broken.
You can get a new adapter fairly easily, but it isn't worth trying to fix a BIOS or hardware issue.
If it's a fairly new DS, contact Nintendo's Customer Service, and see if they'll replace it.
Sep 19, 2009 | Nintendo DS Lite Console
Strange noises, disk won't fully spin or start up...
Your AC adapter is "dying", and must be replaced.
Is it still under "warranty", i.e., you contact LaCie,
get an RMA (Return Materials Authorization) number,
they ship you a new adapter. If you ship them the old adapter,
within a week, they will _not_ charge your credit-card the $30.
Sep 19, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Have the orange light when trying to start laptop,
There is a chance that the power adapter that charges the computer is bad and has stopped charging the battery. Another possibility is that the adapter that you power supply plugs into located inside you computer is malfunction try wiggling the cord and see if the computer trys to come on.
Aug 08, 2009 | Dell XPS M1330 Notebook
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
