Question about Sewing Machines
Made a mistake and took out the bobbin hardware that is held in by two little clips on my nelco sewing machine. it came out in two parts. I was trying to figure out why the tthread was breaking Can you help me get it lined up and back in the machine this thing holds the bobbin and the casin Thanks Jennifer
How do i thread my older nelco j-a38 and what are all the buttons or nobs for
Posted on Jul 30, 2010
  • 202 Answers
Feel the edges with your fingernail on the one part with a sharp point (the hook). If you feel a burr this is where the thread is catching and giving you problems. Needs to be polished with a very fine crocus cloth or your fingernail buffer pad.
Lay the machine back some and put the hook in the hook race. That is the entire round part. The hook will lay opposite a c shaped metal piece in the edge of the hook race. Then put the round case on around it and snap the locks over.
Hope this helped.
Rick
Posted on Sep 05, 2009
I need help putting the bobbin threader back onto a Nelco JA38 sewing machine and the springs are giving me fits. Any help?
Not sure if you are having problems with the bobbin winder or threading the bobbin. This may help:
Nelco JA 38 Sewing Machine Threading Diagram
To avoid awful thread nests under the fabric, be sure to ALWAYS RAISE the presser foot when threading the top thread.
Interestingly, the bobbin threading instructions (above) show the bobbin loading into the bobbin case so it turns COUNTER-clockwise. This is the opposite of instructions for most machines. You can probably try both, the clockwise or Counter-clockwise,and see if one works better than the other.
Be sure to use fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil on your machine. Open it up, while gently wiggling the handwheel, drop a couple drops of oil every place that metal rubs against metal. Avoid plastic or rubber parts! You may even find little round holes throughout that are oil ports. Be sure to get the area around the needlebar, presser foot lifter, feed dogs, the bobbin area, and all the dial and selector mechanisms.
You can find manuals for your machine online (not free!).
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Aug 07, 2017 | Sewing Machines
Releasing clutch that is stuck on Nelco sewing machine. Love this machine have had it for 47 years
Has the machine been regularly cleaned and oiled? Most times, older mechanical machines seize due to old oil turning to glue/varnish and preventing the parts from moving.
Perhaps a bit of Tri-Flow and heat will loosen it. If you are trying to wind bobbins, you can also purchase a stand-alone bobbin winder (one brand is called Sidewinder) for ~$30. It is helpful for many sewists because bobbins can be wound without unthreading the machine and it saves wear and tear on the machine. (Love my Nelco J-28!)
Wheel on right side that controls the needle up and down is very tight...
Jul 09, 2017 | Sewing Machines
I need the manual for a Nelco F600. Do you have it or know where I can get one. I was given a machine but think it has been in storage for a long time! Need to oil and check it out.
A manual for a similar model would be a benefit. Most machines operate and thread the same. Yes, you should definitely clean and lube your machine before trying any sewing. Tri-Flow Synthetic Lube from the hardware store is a good product to use because it does not dry out and turn to glue over time.
Nelco sewing machine manual free
FWIW, I inherited a Nelco J28 and it is the toughest machine in my arsenal. I repair horse equipment with it. The stitch quality is not the best, but it certainly sews most anything thrown at it. The only issue I have with it (and it is my issue, not the machine's) is that it has a side-loading bobbin which means the home position of the needle is also on the left instead of the middle. Having always used a centered needle makes using it seem somewhat unnatural. However, your machine appears to have the front-loading bobbin and centered needle.
May 16, 2017 | Sewing Machines
when was your machine serviced last if it was a year or more spend the money it will extend the life of your sewing machine
Mary
Apr 12, 2014 | Sewing Machines
My mother"ssewing machine willnot pick
I saw Nelco on this website http://www.sewusa.com/Sewing_Machine_Manuals/Nelco_Sewing_Machines.htm
purchasing /obtaining a manual is always very helpful when working with a sewing machine.
However, simple stuff to check, is the needle in the right way, with the scarf (groove) to the back?
Is the needle new and the right type of needle for this machine? Sorry, I don't know a lot about Nelco however, most machines use 130/705H system needles, but there is always the exception, especially with something 40+ years old so it pays to check it out.
And lastly timing, the needle needs to be down at the lowest point as the rotary hook comes around to catch the thread. If this isn't happening, then it could be that the timing is out on the machine. It's never happened to me but it can happen. But I'd suggest you try changing needle, check threading path and bobbin firstly.
Good luck.
Apr 10, 2011 | Sewing Machines
I have a singer 7422. I am trying to wind the bobbin. It should be the easiest part and last time it was. Now when I turn it on nothing happens. I have the manual in front of me and have checked and...
To clarify, take the thread from the spool, through that little clip, loop it around the little metal button piece at the top (should have a diagram on top of the machine), then through one of the tiny holes in the upper side of a bobbin. Place the bobbin on the vertical bobbin winder pin/rod on top of the machine then be sure to snap that pin/rod all the way to the right to engage motor. Then try. Most of the time people forget to push the bobbin winder pin/rod to the right which leaves the machine in sewing mode rather than in bobbin winding mode. Easy mistake. ;)
May 27, 2008 | Singer 7422
Janome 9000
I have a Janome 9000, was sewing and broke needle, replaced and broke another. I didn't have machine threaded, took out bobbin and would sew a little and stop saying thread broke. I took off top plate and started machine again, sew a little and stop saying thread broke. So I took out bobbin case and sewed again and stopped repeating the message. Everything looks OK, bobbin case and top plate. I guess I want to know if the timing could be off or do you think it is the computer part of the machine...Should I take it to the Sewing Machine Shop??
Apr 30, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
190 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
