Question about Ryobi Garden
Clutch removal on 31 cc weed eater - Ryobi Garden
  • 279 Answers
Break the engine away from the shaft on the shaft side. I think 4 bolts/screws. Once you have that open you will seethe part that goes over the shaft. To take it off, hold the part with one hand and remove a screw in the center of the part using a #15 TORX screwdriver. Take off the part and under it is the clutch. Good luck...Lee
Posted on Sep 05, 2009
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Need to know the gas mixture and spark plug gap distance for 31 cc McCulloch EZ Pull weed eater
The plug gap is 0.6 mm (0.025") and the recommended plug in an NGK is BM6A.
May 24, 2011 | Garden
Weed Eater WT 3100 how do I remove/replace cutting head
If the unit has a clutch, it will spin up to the crankshaft of the engine. Try to grip the top part with something to hold it..if there is an arbor there, it can be jammed in place by inserting a small blade screwdriver in one of the holes, If the unit has no clutch (but it probably does), you would remove the spark plug...rotate the engine so the piston is down, and insert a lenth of clean soft rope in the engine so that when you turned the whole drive and crank, the engine would lock up compressing the rope allowing you to remove the head assembly.
Jul 31, 2010 | Garden
I have weed eater model FX26SC it starts and when I put it to run the weed eater doesn't spin but is running
Either the clutch is worn out or the flexible drive shaft is broken. Either repair is likely to cost almost as much as a new unit.
May 16, 2010 | Garden
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
My husband took his Poulan Pro 31 cc weed eater/trimmer apart and now needs an engine diagram to put it back together. Where can I get a downloadable one ?
Go to the Poulan web page http://www.poulanpro.com/node6556.aspx and enter the model number of the string trimmer. If the trimmer is a Weed Eater brand (owned by Poulan) then go to this page http://www.weedeater.com/node6507.aspx. I think you can also locate older model manuals in their archives.
Apr 10, 2010 | Poulan Garden
I have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Sep 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
141 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
