Question about Brother LS-2125 Mechanical Sewing Machine
Brother xl 2230 - cannot fill spool as holder does
Brother xl 2230 sewing machine - cannot fill spool as holder does not spin. Needle is in fixed position but spool spindle does not turn
  • dsweatherall
    dsweatherall Jan 26, 2013
    kk my problem is i had a blockage in my bobbin and took it all out to clean it and now having trouble getting it back in properly.. the guide not much help
  • Brother Master
  • 1,388 Answers
Check the bobbin winder rubber......remove the top cover and take a look. Remove worn rubber and use as a sample when you go to the Brother Store....also have your model number handy. If you cannot access easily, phone Brother store and ask for a quote to replace.....if it is any more serious they should confirm with you prior to doing additional work.
Posted on Sep 06, 2009
  • juts_pal
    juts_pal Sep 12, 2012
    Martyn, could you share how you installed this part and how did you remove the leftover gunk from the old ring?
    Problem Solver:
  • 10 Answers
The Rubber O-Ring on my XL-2230 turned into a gel like substance.The rubber actually decomposed. So I went to the hardware store and found a replacement O-Ring made of a better material. Winds great now.
Posted on Jan 28, 2012
  • juts_pal
    Eddie, could you share how you installed this part andhow did you remove the leftover gunk from the old ring?
My brother XL-2230 wont actually spin round. it did, i accidently fit the power peddle, and now it wont sew/spin round??
if the machine was threaded at the time, the upper and lower threads will have jammed and now are preventing the machine from turning
Feb 17, 2014 | Brother XL-2230 Mechanical Sewing Machine
Can't fill empty spool
The bobbin winder has a small rubber tyre...probably damaged or broken and needs replacing
Jan 07, 2014 | Brother XL-2230 Mechanical Sewing Machine
How do I use the double needle
first you take out the single needle, then you insert the double needle the same way you would the regular needle
the flat side goes toward the back of the machine inserted all the way up into the needle holder
then you take the 2 spools of thread & put them on the spool holders
then you thread the machine with the first spool just like when your going to sew normally with one needle & then you thread the first needle
& then the second spool is threaded the same path as the other spool,, ever guide & then you thread the second needle
then you make sure you have thread tails for top & bobbin thread of 3 to 6 inches long, pulled toward the back of the machine before you start to sew
happy sewing
Sep 05, 2011 | Brother XL-2610
When drawing thread up from the shuttle needle wont go down
Sounds like your hook to needle timing is off. When you sew through thick materials, a lot of machines have issues where the needle sticks in the fabric but all the internal parts shift and this causes the hook to needle timing to go out. The begging signs of this is skipping stitches. You will have to have you local independent sewing store do this adjustment for you
Hope that helps :)
Chris
Jun 05, 2010 | Brother XL-2230 Mechanical Sewing Machine
HOW TO THREAD THE BOBBIN
Take the thread-end from the thread spool to the left, around the bottom of the "silver" "button"; across the top of the button and back to the right to the bobbin winder.
Run the thread-end through a hole in the side of the bobbin spool, hold onto the thread (pull through about 5" of thread) and place the bobbin spool onto the the bobbin winding pin.
You may have to turn a bit to the left or right to get the spool in place. Push the bobbin spool to the right; against the bobbin winding wheel.
Press on the power pedal - keeping hold of the thread-end.
As the bobbin fills, the thead end will twist.
When you can not longer hold on. Stop the machine and clip the thread end then continue to wind the bobbin.
You can view and download a manual here (free) - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL2230
Mar 25, 2010 | Brother XL-2230 Mechanical Sewing Machine
Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Apr 26, 2009 | Brother XL-2230 Mechanical Sewing Machine
Bobbin holder turns and keeps bending needles
hi,
the whole upper assembly may have come out of alignment when the machine bent the needle, the upper cover may have to come off, and study the inner metal area where the needle is attached for alignment bolts or screws, maybe one has come loose. On ours if you choose the zig zag and adjust it all the way out it will do that everytime. maybe download the user manual at www.brother.com and see if theres something in there also.
J
Jul 23, 2008 | Brother XL-2230 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
308 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
