Question about Acer Aspire One PC Notebook
My Acer Aspire One A150 screen is damaged and in inverted colours
I was using my netbook and suddenly the screen turned to inverted colours. I tried to change the settings in windows and when that failed I connected my netbook to a lcd monitor with a vga cable. The screen was fine on the lcd monitor so I have come to the conclusion that the screen is damaged. The screen is inverted colours even at the acer boot screen at the beginning so I know it is not a problem with the operating system.
Has anyone had that problem and if they have were they able to fix it or had to send it of to acer. If you did send your netbook with this problem to acer were they able to fix it, thanks
  • 2 more comments
  • calebkingcot Sep 05, 2009
    I bought this Netbook in march so it is definitely covered under warranty. I had a problem like this when I left it in the car while on Holiday and I got black splodges. I got somebody to replace the screen for me and it was working until now. Do you think this will effect my ability to get a replacement. I have heard bad reviews of the acer technical help, Have you had any experience with them?
    Yes, the guy replaced the lcd screen inside the netbook as it was damaged. Do you think I will have problems getting Acer to fix or replace it as they will know it has been opened. Would it be best to explain the situation to them and hope for the best.
    Thanks
  • drsrinivas May 11, 2010
    For sure this is due to hardware damage or problem with cable.. How old is you netbook ?
    Acer will be able to fix it. Are you still covered by warranty .? (u'll have it done for free in the absence of any physical damage)
    Problem Solver:
  • 5 Answers
"I got somebody to replace the screen for me and it was working until now" this more likely affects your warranty as the warranty seal is tampered..
What did the guy do to get it right did you replace something or just got it serviced..??
I don't user acer but my friend had problems with his lap DVD drive n got replacement. It took 2 weeks though
Posted on Sep 05, 2009
  • drsrinivas Sep 05, 2009
    "Would it be best to explain the situation to them and hope for the best". - Not at all .
    Opened is opened. The replaced screen may be of poor quality which might have given rise to current condition. Chances of replacement are very little. If you explain they won't just accept your claim but may be you can just try your luck without explaining anything.
I had this problem. When I took apart the screen, there was a loose screw on the circuit board behind it. The screw is in the middle of the circuit board behind the screen.
Posted on May 14, 2010
How do you format an acer netbook?
When the acer screen comes up press alt+F10, if it doesn't work then you need to restart your computer again, load the BIOS and enable it.
May 19, 2010 | Acer Aspire One A150-1006 Notebook
Acer Aspire One Netbook screen does not come on when computer is turned on.
There is a LCD inverter (tiny circuit board) that connects the screen to the motherboard, try replacing it.
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One A150 : screen all dark after changing it
It is an inverter problem. Check all cable attachments first, then change out the inverter.
Feb 17, 2010 | Acer Aspire One A150-1049 Notebook
My screen on my toshiba laptop screen is going in and out do I need to buy a new scren/
Most likely your issue is caused by a failing LCD Inverter. You will need to have this replaced. Part is available here: http://cgi.ebay.com/Acer-Aspire-One-A110-A150-LCD-Screen-Inverter-B089AW01_W0QQitemZ190363835846QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2c52919dc6
This site explains the process for an Aspire 5100 which can also can be used as a reference for your Aspire One model http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Jan 14, 2010 | Acer Aspire One PC Notebook
My daughters acer one goes black after start up
Take the netbook into a dark room and see if you can see the screen. There are three possibilities here....either the screen is on and the backlight has failed or there is nothing on the screen because the inverter has failed or the screen itself has failed. If you take the netbook into a dark room and shine a flashlight on the bottom section of the screen, if you see the desktop or test etc. then the screen and inverter are good and the backlight has failed. If however you don't see anything on the screen and you are sure the laptop booted, then most likely you have lost the inverter or the screen itself.
Nov 08, 2009 | Acer Aspire One A150-1006 Notebook
Screen flickers on Acer Aspire A150 Netbook
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 08, 2009 | Acer Aspire One A150-1006 Notebook
Need a virus scanner compatible with ACER A150 Netbook
TRY DOWNLOADING AVAST,ITS ONTIME SCAN AND WORKS LIKE A DREAM.
FREE ON THE NET
Jul 04, 2009 | Acer Aspire One PC Notebook
Acer Aspire One  PC Notebook Logo
900 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
