Question about Emerson Audio Players & Recorders
I have emerson mtp ver 3.50.00 it will say music has been added on computer but dsnt show on mp3 its not on voice mode
Ok, it took me several hours to figure out such a simple problem. I couldn't open my Emerson 3.50 up on the computer. Therefore I couldn't delete any of the music or add more. It is because it isn't downloading the right driver. You have to manually search your computer for the USB Mass Storage driver and install that. Go into Control Panel, then hardware/sound, then Device Manager. When in device manager find your portable devicse and click on it. Then click on Audio Player. choose update driver and instead of auto driver select, choose "Let me pick a driver". Then choose USB Mass Storage for the driver. Once it has updated you will see all of your songs on Media player. And it works as an MP3 player should!
Posted on Sep 17, 2009
Not enough space
You should have your Sansa player set to MTP (Media Transfer Protocol) when you are using it with any of the supported subscription (ie) iTunes, or Rhapsody music services. The main purpose of MTP is to transfer media files and associated metadata to/from devices, with optional additional support for reading and setting of device parameters such as special DRM-related device parameters for restricted content. Otherwise, you should set it to MSC (Mass Storage Class), which is the normal USB mode for storage devices like thumb drives, and camara SD memory cards.
See this tip posted here Tips on MP3 connection problems..
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode. Things to do if you are getting not enough space mesage.
1. Turn device OFF. 2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold. 3. Connect the device to the PC.
If you added songs to the device in MSC mode, then you switched to MTP mode, you will not be able to see the songs added in MSC mode and vice versa, though the space used on the player will still reflect their presence. Switching modes should make the files show up. For example, switching back to MSC or MTP mode.
For older players - e200v1, c200v1, c100, m200 - the files become hidden files if the modes are switched. An easy workaround is to edit the folder options to show hidden files.
STEP 1 - Edit the folder options of the computer to show the hidden files
Windows XP: 1. Double-click My Computer. 2. Under the Tools menu, select Folder options, then click the View tab. 3. Under Hidden files and folders option, select Show hidden files and folders. 4. Uncheck the Hide protected operating system files (Recommended) check box. 5. Click Apply, then click OK.
Windows Vista: 1. Double-click Computer. 2. Click the Organize button on the upper left corner. 3. Click Folder and search options. 4. Click the View tab and select Show hidden files and folders. 5. Uncheck the Hide protected operating system files check box. 6. Click Apply, then click OK.
SOLUTION 2 - Perform a Check Disk.
STEP 1 - Switch to MSC mode 1. On your Sansa player, switch the USB mode to MSC. 2. Connect the Sansa player to the PC.
STEP 2 - Perform Check Disk 1. Locate the Sansa player under My Computer. 2. Right-click the removable drive associated with the Sansa player, and select Properties. 3. Click the Tools tab, and then click Check now. 4. Click to select the Automatically fix the file system errors and Scan for and attempt recovery of bad sectors check boxes. 5. Click Start.
SOLUTION 3 - Format the player in MSC mode or MTP mode.
Jan 16, 2011 | SanDisk Sansa m240 MP3 Player
My Sansa e260 player works fine, plays my music and everything, but I have a problem with adding/deleting music. When I connected it to my computer, it did not recognize the player and it did not show up...
MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion..... make sure your usb 2.0 driver is installed..Syncing to wmplayer puts music in the mtp music folder. change usb modes again and use the explorer to see the sansa msc lets you sync any Q/A IM or email me @ Schmead01@yahoo.com
Jun 23, 2010 | SanDisk Sansa e260 MP3 Player
I cannot access the music on my Samsa M230 via USB to PC. I would like to copy the music off the sansa and add new music, but windows media player doest show any music files on the m230 drive
There are 2 modes the player can connect to a computer:
1. MSC mode: the operating system, seeing the player as a removable disk on "My Computer"
2. MTP mode: added software, when an extra program is started the player is detected in this application software: e.g. Windows Media Player
When songs show up on the player but not on My Computer:
1. The player is in MSC mode and music has been put on the player with a program in MTP mode
or
2. The player is in MTP mode and music has been put on the player
using Windows Explorer in My Computer in MSC mode
In your case the solution should be:
Switch the player into MSC mode and look in Windows Explorer for
a driver letter with a capacity of about 512MB memory.
How to get the player in MSC mode:
Using the menu on the player:
From the main menu go to Settings Menu > USB and select MSC mode.
Using the hold switch on the player:
1. Turn device OFF.
Explore "My Computer", looking for the players content showing up as a drive letter (about 512 MB sized for the m230)
Click the drive letter, select your files and "copy + save" or "drag and drop" them to a location on the computer.
When needing more help, just post a comment.
Dec 30, 2009 | SanDisk Sansa m230 MP3 Player
I lost my cd and need to reinstall the driver and software
Sorry but there are no specific drivers on the CD for this player. I've had this player since '05 and was trying to get it installed under Windows Vista with only limited success. This player seems to work best with Win XP.
The c150 has two modes of operation MSC and MTP. In MSC mode Windows recognizes the player as a flash drive. You create folders using Windows Explorer just like you do on any hard drive and then copy your music files into the folders. The second mode (MTP) works with a music player such as Rhapsody or Windows Media Player (ver. 10 or higher). SanDisk bundled Rhapsody on their CD and I just installed it (today) on my Vista PC and it seems to work OK. Any files dropped on the player in MTP mode are invisible to the music player running in MSC mode. However, all files added to the player, regardless of the mode used, are visible as one big happy list when you use the player.
You set the mode you want to use before plugging the player into a USB port by going to "menu/settings/USB" on the player then choose either MSC or Auto Detect (defaults to MTP).
SanDisk has very little tech support info about this player on it's web site. I hope this is helpful.
Jul 12, 2009 | SanDisk Sansa c150 MP3 Player
Change MP3 from USB to MSC mode
Usb mode is in settings push center button choose between msc or mtp.... MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installed
Jun 27, 2009 | SanDisk Sansa e260 MP3 Player
I HAVE AN EMERSON MP3 PLAYER VERSION 3.5O.00. WINDOWS MEDIA PLAYER SHOWS THAT I HAVE MUSIC LOADED ONTO THE DEVICE BUT WHEN I REMOVE IT FROM THE USB PORT TO LISTEN TO MY MUSIC... THE MP3 PLAYERS SAYS THERE...
I have an Emerson 2gb MP3 player model EMP 312-2, not sure if this info is for you or not. Make sure you are in the MUSIC MODE, when you use the menu button to go from music mode, voice mode, settings etc. you must push menu button again when the mode you want is hi-lited. I had a similar problem. Files were loaded (my music is on my harddrive already so I just copy to mp3 player) but when I turned player on it said no files. AHA, I finally realized I had somehow got into the voice mode and I did not have any voice files, so it said no files. I then went to Folder Mode and it only said micin.dir and it was empty, THAT WAS BECAUSE I WAS IN VOICE MODE, when I switched to music mode, they were all there. I know this sounds very rudimentary, but I am pretty computer literate and had no idea how I switched to voice mode. Before I figured this out for myself I called Emerson customer service, they said it was bad firmware and send it back. If someone there had walked me through what I just told you it would have saved me a lot of time. Hope this helps.
Jan 23, 2009 | Emerson BAR900 MP3 Player
Sansa Clip 2GB MP3 player
The user manual wil lshow you how to switch your USB mode from MSC to MTP:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
Problem viewing recently added songs
Move those songs to the My Music folder, and they will all be in the same place on your computer. Switch to Auto USB mode instead of MTP - the hidden music folder should become visible.
Jun 25, 2008 | SanDisk Sansa e270 MP3 Player
Mtp mode
uuh no it dosent...nice try tho
Jan 05, 2008 | SanDisk Sansa e250 MP3 Player
NoSpaceForDB Please Delete MoreThan4.0MB
hmmm i'm not familiar with the problem but try this.
First open your mp3 player and go to settings. Under the USB menu change it to MSC. Then plug in the mp3 player to the computer. Open the My Computer on your desktop, right click on the Sansa mp3 player and click Format. Make sure Fat32 is checked and Quick format is UNchecked. Then format the mp3 player. After that it should be clean and work just like a USB drive.
Let me know if this helps!
Apr 07, 2007 | SanDisk Sansa c140 MP3 Player
906 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
