Question about Karcher 2500 PSI Pressure Washer
Powerstroke pressure quit after 15 min. won't restart
Won't restart engine
Have a powerstroke gc 190 honda pressure washer the pressure is great for a little while then it seems to bleed off its a brand new machine. Not even 15 minutes on it.
Posted on Feb 06, 2010
Had a Kohler 17.5 command installed on mower to replace failed 16 same. Will run about 10-15 min then just quit after waiting 30-45 runs ok nut quits again after 10-15 min. ??? Just changed oil.
sounds like the fuel cap may not be vented right or plugged. loosen the cap and try it if that is it replace the cap or clean the vents. be sure the fuel line is away from the engine and getting plenty of air flow off the engine. if the fuel gets to hot it may be boiling the fuel causing it to die till it cools off. if these don't help you may look into replacing the coil.
Jul 03, 2017 | Garden
Engine runs about 15 min. then stalls and won t restart till it cools a bit
Could be a coil, relay, fuel pump, or several other components.
Do you loose fuel pressure or spark when it stalls ?
Aug 26, 2013 | 1998 Saturn SC
Won't restart in Warm Weather
The first thing you need to do is run the system for fault codes, any Autozone will do this for free, ask for a OBD2 fault code test. If no codes show check the fuel pressure next time this start problem occurs.
Jun 12, 2013 | 2003 Pontiac Aztek
Dryer motor hums ant wont start
Thais probably the motor but it might be something in the blower housing. Their are lots of movies on youtube that will show you how to do it. Now here is my home movie of a dryer like yours:
Sep 08, 2012 | KitchenAid Dryers
Engine light stays on and won't start after fuel fill up
I would try replacing your Fuel Filter first. It could be that simple.
May 13, 2017 | 2006 Volkswagen Jetta
My x5 3.0i 2006 t won't start this morning but temperature, gas level clock were wrong so I turn the engine off and restart a couple times it won't start and I saw message trans. false safe...
no. I'd suggest to disconnect a battery for 15 mins, reconnect, wait for 5 mins and try to restart. If it doesn't help (sometimes there's a program block to prevent stealing equipment) call a dealer
Aug 04, 2017 | 2003 BMW 5 Series
I have a 1992 dodge dakota 3.9l v6 when im driving the motor will just cut out. sometimes it will start right back up and sometimes it will take like 15 to 20 min before it starts back up. no check engine...
One way to confirm if it's a spark problem or fuel delivery problem is, when it quits and won't start, remove air intake hose at throttle body opening and spray some WD-40 ( 2-3 sec. ) into throttle body, then try to start. If it fires up momentarily then stalls again, have fuel pressure tested. The WD-40 acts like quick start and if that fires the engine over, then you have spark, but not enough or any fuel.
If that doesn't help, no start at all even with WD-40 sprayed in throttle body, then I'd think real serious about changing the hall effect pick-up ( pick-up coil) in distributor, if you have that style distributor. It is located under distributor cap below rotor, it looks like a round black plate in shape with wiring and connector at end of it. Remove cap, remove rotor, and lift it out, unplug from connector. Replace it in same position, then re-install rotor, then cap. They were a pretty common problem in earlier years. Engine would just quit anytime after it was warmed up, then sit for 15-20 minutes, then restart and go for a while and do it again.
Sep 03, 2011 | 1992 Dodge Dakota
When saw gets hot there is a ping sound than shuts down
your clutch needs re bilt and check for kick out if it has that make shure its off
Aug 29, 2009 | Homelite Garden
Karcher 2500 PSI Pressure Washer Logo
2,371 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
