Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 57h81 location of vidio baord
The picture is scrambled until warm , i have been told the solder caps are bad on the video board.
    Genius:
  • 1,694 Answers
Actually, called the Hyper board = No longer available.....
1) It is a stand-up PC board mounted to larger board .....
some soldering needed to remove and rebuild....
2) Change any / all bad 10mf / 16v capacitors....re-install....T.
Posted on Dec 08, 2007
  • Vista Electronics Dec 08, 2007
    PS can be done by rebuider like PTS Corp. or by a senior
    technician skilled in smd replacement...............T.
  • Vista Electronics Dec 10, 2007
    Hyper board part # 23786198 rebuild only...........T.
  • 50 Answers
Yes they are bad, they are surface mount on the digital board. Board replacement is advised. They are not easy to change if trying to replace the capacitors.
Location of convergence chips in Toshiba 57H81.
hello if you can use a soldering iron you shouldn't have any problems but you will need to test the resistor in front of the ic and the capacitors at either end of the ic ! the ic usually located to the right hand side of the tv behind the tuner board connected to metal frame called a heatsink 2 big black chip good luck
regards
shaun
Mar 27, 2010 | Toshiba 57H81 57" Rear Projection...
Basic cable scrambled on ANT input but not PIP
it sounds like you have the common problem with these models. The poblem has occured so offten that toshiba issued a service bulliteen about it. There is a problem with a cuircit board called the Hypermodule its a signal processing board/ the ideal situation would be replaced this board but it has happen so much it may be difficult to find this ooard so this board can be repaird. The secound problem is to fix this board 11 very very small parts called capacitors need to be replaced. i have also replace these and only someone advance in solder should attempt it very small. twezers and magnifer. You can hire someone but it very labor intensive. Our shop charges 300 just in labor It can be fixed but I would adviise its just no worth it
Dec 09, 2009 | Toshiba 42H81 42" Rear Projection...
Picture is scrambled until it warms up. Can play DVD without any issues, but all other video inputs are scrambled for 30 - 40 minutes.
unit has a bad hyper module,NLA thru toshiba.try contacting tristate module or pts to see if they still rebuild them.toshiba part-23786198,MVPU13,PD0264A
you mite have to search to web a bit to find one if they dont rebuild them anymore.
Sep 29, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba Projection Television Problems
we are facing server problems please reply to me at coolguy4u_008@yahoo.com
don't worry i have found your part..
Apr 11, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h81 location of hyper board and remove procedure
Hyper board is located directly behind the input board, this is where all the tv conections are, then they are two tabs soldered from the bottom of the board then it simply unplugs, But replacing all those capacitors on that board can be a little tricky, replace all 10up @16volt caps and that usaly repairs the board
Feb 12, 2008 | Toshiba 57H81 57" Rear Projection...
Distorted Picture Upon Startup
You have a bad capacitor in your power supply.
Dec 22, 2007 | Toshiba 57H81 57" Rear Projection...
It is a toshiba 57h81 and i would like location of vidio board
Check this site for the solution
Read down basically it a heat
and esr problem with capacitors
also check here
for the tools etc you
may need if you are going
to do this yourself
Dec 08, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Picture Jumps/flashes for first 5 minutes
There is a module called a hyper board that is vertically mounted near the jack panel. Inside the module are 10mf/25v capacitors they are grtting weak. The module is fully shielded and pluggs into a socket. the module has 4 tabs (2 on each end) that must be unsoldered before it can be unplugged. This repair should be done by a qualified technician. The caps are surface mounts and very small. Unless you have excellent soldering skills and a rock steady hand DO NOT ATTEMPT to repair this problem on your own.
Nov 16, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 picture bounces. Can't tell if horiz. or vertical.
Unstable picture, wavy, jittery, and loss of sync are a symptom of bad capacitors in the hyper module. The problem is worse when the set is cold, but when warm the sympton gets less or goes away. In the latter stages the problem never gets better even after the set has been on for hours. There are about 6 surface mounted caps (10mf/16) inside the shielded Hyper module. The module is vertically mounted behind the jack panel and can be unplugged from its socket after unsoldering the 4 anchor tabs on the bottom side of the PCB. This type of repair should be made by a qualified technician do to the complexity of chassis removal and expert soldering skills.
Oct 25, 2007 | Toshiba 57H81 57" Rear Projection...
I had the same problem and followed the instructions from Jack and my 57h81 is bak up and running. Thanks Jack. RonD
Jul 02, 2007 | Toshiba 36HF72 36" TV
Toshiba 57H81 57" Rear Projection Television Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
