Question about Baumatic MEGAWDSS Front Load Washer / Dryer
Baumatic washer draining but not spinning
Baumatic washer not spinning properly after wash cycle
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Posted on May 02, 2010
Hi, I have a baumatic BWMI 1206.1 washing machine. Once a cycle is started it never completes, I have to manually set to spin. Do you have any idea what could be wrong?
I'm not a washing machine repairman, but this sounds suspiciously like a worn-out or defective timer. Only guessing here, but perhaps (USD) $50 in parts plus the cost of the service call. This model seems to have a fairly good reputation and considering the cost of washing machines, I'd probably be inclined to have it professionally serviced. It doesn't sound like something you can fix yourself.
Also, most newer washers will not spin if the load of wet clothing is not balanced (evenly distributed) - of course you have likely checked this. Good luck
Jan 04, 2015 | Baumatic Washing Machines
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
My washing fills and drains properly, but will not agitate or run the spin cycle. I sounds like it is going through the cycle properly, but will not turn the drum (spin cycle) or agitator.
Try picking a different wash cycle, instead of your annual quick wash cycle opt for the longer wash cycle and then you may find that the spin cycle may kick-in, hope this works for you, good luck!
Apr 17, 2011 | GE WBSR3140DW Top Load Washer
My washer seems not to spin properly during the rinse cycle and will not spin now i get what i assume is an error message ue when its time for the spin cycle to begin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 18, 2011 | LG WM2455 Front Load Washer
Water not draining
heatman101
Sep 03, 2010 | Baumatic BTWM4 Front Load Washer
The machine won't drain
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 02, 2010 | Baumatic BFWE1470 Front Load Washer
My Baumatic MEGA6SS washer is still full of water after the cycle is complete. Tried starting it on 'Drain' and nothing happens.
sounds like your drain pump is not working. that will be the case if there is no noise. if you hear something when it should be draining, check the screen to be sure it's not plugged.
Oct 11, 2009 | Baumatic MEGA6SS Front Load Washer
Washer does not spin after wash cycle
Problem solved. It was one of the resolutions posted by one of your clients. TKS. PS this one of the best problem solving sites that I have seen. Great Job Rick
Jan 29, 2009 | Frigidaire GLWS1233A Top Load Washer
Baumatic washing m/c btwm4
check that the drain filter is clear, if thats ok its probably going to be the electronic module at fault.
Nov 25, 2008 | Baumatic BTWM4 Front Load Washer
Baumatic MEGAWDSS Front Load Washer / Dryer Logo
920 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
NOEL
NOEL
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
