Question about Cell Phones
I can't get my Palm Tro Pro to sync with my computer. I have uninstalled the program several times.
Palm sync doesn't work even though it says sync complete.
1. Right click on red/blue arrows on lower right of pc
2. Select custom
3. Check direction for all
If you found this helpful, please post as such. If this fixes of coarse, please post as fixya
Jan 02, 2009 | Palm Z22 Handheld
Cd doesnt install palm desktop software (palm z22)
You're saying you trying to install an appointment on your PDA. Has evrything worked before?
Dec 30, 2008 | Palm Z22 Handheld
Treo 755p Getting Stuck During HotSync
If you have another computer you could try installing the software on that to see if the Treo will sync.
This would determine if it's a computer problem or if it's your Treo.
When you unchecked the datebook to sync after uninstall/reinstalling, was it able to sync then?
I have had other palms get hung up to a certain point during the sync, but uninstalled the program or disabled it from syncing like you tried and it usually works.
Sep 24, 2008 | Palm Treo 755p Smartphone
Cannot uninstall WinFax Pro 10 even after doing manual uninstall.
For the next 12 hours you can download for free cleanse UnInstaller Pro At Giveaway of the Day. Install it and then keep attacking every bit of Symantec you find on your computer. You may have to go back several times and keep on deleting more pieces of the programs that were there but this truly works. It's the only program I found so far that could get rid of WinFax Pro including the stuff provided by Norton. Good luck
Jul 02, 2008 | Symantec WinFax Pro for PC
Sync problems with windows vista
I got a Vista computer in April and have problems also. You need a special program to install the maps. email Garmin and they will send you the link. An SD card reader/writer is MUCH faster than the sync.
I didn't have syncing problems until after I tried to install Documents to Go. I had to remove Doc to Go v6 because it was making my computer unstable. Doc to GO V10 works with Vista but requires Palm OS6. Garmin says that Palm OS6 can't be installed on the Garmin iQue because they added proprietary software to OS4. I believe my sync problems will disappear after I reload the Palm Software.
Feb 18, 2008 | Garmin iQue 3600 GPS Receiver
Syncing of palm times out
this is producers mistake :(
Sep 23, 2007 | Palm Treo 750 Smartphone
Tungsten E - HotSync with Outlook 2003
Don't skip the initial HotSync for secondary computer! Alright, I figured this one out on my own and figured I'd post what I'd learned so that others don't have to endure the teeth mashing, hair pulling, snarling frustration. (self induced as it may be) My experiences have taught me to not always trust a cookie cutter installation wizard...especially for custom app installations (ie: primary = home, secondary=work, total sync, no priority). So, I did not perform the initial sync during installation of the palm software fearing that the new installation would NOT recognize that the work computer was a secondary machine and resultantly wipe out the old palm data from the primary machine. Turns out, as I saw in many other unrelated posts, that it's difficult (if not impossible) to specify conduit direction to outlook 2003 outside of the initial sync (this prompted me to specifically look for conduit direction during install). So, this wizard is one I should have trusted...by mistake...because of weak program design. By the way...once I specified sync with outlook during the initial sync, EVERYTHING works fine despite not having installed the two "imperative" conduit updates (they were uninstalled after several previous failed attempts at this). Hope this helps
Sep 12, 2005 | Palm Tungsten E Handheld
Outlook will not sync with Tungsten C
Check you sync part of your desktop program and make sure you have outlook checked for transfer. Right click on Synch on bottom tray and select custom set uo
Sep 11, 2005 | Palm Tungsten C Handheld
What is LyncHS, and Why am I crashing EVERY day?!
LyncHS, Zire 72, Soft Reset and XP Professional I do a sync and my PDA crashes... I have to do a soft reset almost every single time. I have been having the same exact problem but cannot seem to find anyone who can help!!!! Before I got my Zire 72 I had this problem with my Sony Clie. I even narrowed it down to this LyncHS application and still could not get help. I finally purchased a new PDA because I was getting tired of this happening. It was not the PDA... it is the Palm OS or a Palm application that is a problem. I have not installed ANY third party applications so PalmOne needs to quit trying to tell me to uninstall those. MitaMe, you are absolutely correct... this is not acceptable and since I am not the only one having problems, I fully expect PalmOne to take it more seriously and try to resolve it. I should not have to perform a soft reset most every time I sync on my Windows XP Professional PC. By the way, I sync on my computer at home which is not Windows XP Pro and this does NOT happen.
Sep 11, 2005 | Palm Zire 72 Handheld
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
