Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Need someone to explain in detail how to change the water filter ....i have a replacement just don't know how to do it
  • Whirlpool Master
  • 1,606 Answers
At the bottom on the kickplate ( by the picture on this thread , you didn't give a model number ) twist the slot under freezer door , to the left and slide out filter . The filter slides off the holder . Slide new filter on and reinstall into the hole , twisting the holder clockwise so it seats .
Posted on Sep 06, 2009
Is there a way to increase the water flow (pressure) from this faucet?
There should be shut off valves under the sink ( 2 if both hot and cold water)check to see if they're open all the way.also check the risers (water lines between valve and tap).If someone installed a cheap plastic line it could be too small ( easy to change) .
Apr 11, 2015 | Plumbing
Replaced water filter on a Maytag refrigerator it uses whirlpool filter. when filter is replaced and you try to use the water dispenser you get a loud grinding noise from the filter, how do you fix this?
I need to know which model you have, because i would explain the issue you have better. I thin it would be a MSD model and it could mean a board collision in the touch panel to the dispenser.
Please let me know your model so I can help you further.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 01, 2013 | Whirlpool Refrigerator Water Filter
How do I change the water filter for the refrigerator, Samaung RF323TE
Page 13 of the User Manual explains where and how to change the water filter RF323TE User Manual
Click link below for instructions
Where Is The Water Filter And How Do I Install It on my French Door or Side-By-Side Refrigerator?
Or click HERE If you have questions or trouble navigating the Samsung site please ask questions and I will try to assist you, Thanks Sea Breeze
Mar 31, 2013 | Samsung RF323TE 31.6 cu. ft. French Door...
I have a side by side refrigerator & the water filter light is red & the filter needs to be changed. The refrigerator was manufactured 11/04 model # ED26HEXNQ00. I don't know what kind of...
The light will just come on based on time not on if the filter is really need to be changed, you can push and hold the button to reset it, and another six months or so it will light up again. I do not have the same model as you, but mine is in side the ref. top right side, others are on the water line in back.
I have two filters before the refrigerator on mine still go's off I just reset it. If the filter is really needing to be replaced your water would slow to a trickle.
Jun 30, 2011 | Whirlpool Refrigerators
Changed water filter, and now no filtered water comes out. Water had slowed, and it stopped making ice, so replaced the filter like always, and now no filtered water comes out at all Bought the same...
Don't know which filter you use, so this might not work. Try reversing the filter to see if it got installed incorrectly.
If not, make sure the the water line didn't get kinked and that the valve is open.
Jun 08, 2011 | Kenmore Refrigerators
Intex Deluxe Saltwater System & Filter Pump Model 8111. Light comes on, code is 88 but there is no suction, there is hum. I have followed directions on this post for little or no suction, put in new...
I have the same problem! We need a better explained solution. bought from a sale and don't have a manual. I have a new filter in it and full water pressure and just a hum. Only code 88 shows up and pump seems to be getting warm. lease explain solution. you can send solution to wilfam220@yaho.com Thanks, Ken
May 24, 2011 | Intex Automatic Salt Water System for ...
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Hayward H400 lights up fine And heats up but
Thank you for posting your question here on Fixya.com.
When you say 'relight it', what do you mean? Poor water flow would lead to the unit overheating in time and it would shut down; explaining both your symptoms as well. Perhaps you need to clean the filter or if it is a cartridge filter, replace the element inside. If that is not the issue you will likely want to hire a professional. Things like taking gas pressure readings are best done by someone in the know. If you have the tools and ability, please reply and we can try to walk you through the process.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 09, 2010 | Hayward H-series Electronic Gas Pool...
No water, no ice, but new water filter cartridge
If it was running before the filter change you need to purge the filter cartridge of the air in the lines. Also check voltage on the back on the water control valves . While someone presses dispenser you should get 120volts AC on the plug receptacle side for the dispenser . Let me know what you find, Sea Breeze
May 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
