Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Fridge working but not cooling.
Fridge is not cooling. Lights work and fan could be heard. Took off the back and I can see a black "pot" like thing. I think thats the compressor. Attached to its side is a white componet with wires. I think that white componet is making a periodic click sound. I hear a click every few minutes - the power to the fan seems to slow ever so slightly - then another click a few seconds later and then it does it again a few minutes later. I don't think the compressor is making any noise. The Compressor is hot to the touch - I did unplug it and let it completely cool down but when I plugged it back in same problem. IF the compressor is bad, is it worth it to fix?
  • Whirlpool Master
  • 1,606 Answers
The white component you see , is the problem . That is the overload/relay . These short due to power surges , dirty coils in the front bottom of refrig , or just by age . They short , to save the compressor , when one of these happens . The part number you need is # 8201786 . This part just prys off (maybe one wire clip ) , easily replaceable with instructions included with the part .
Posted on Sep 06, 2009
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
Freezer cold but fridge warm
first leave it off for 24 hours, and then put it back in operation. if its doing it again , then chck the heating element, defrost timer...
Apr 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
Feb 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Refrigerator does not work but the freezer works fine!
most fridges are cooled by the freezer. There is usually a fan in the freezer section that blows cold air in the fridge section vial some duct work. I expect that the fan has failed or that the air passage is blocked. look inside the fridge, near the very top on the side next to the freezer. You should see a vent/grill.
Jun 22, 2017 | Refrigerators
Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Nov 22, 2007 | Refrigerators
Hotpoint Frige
The main computer is bad. the small square panel axcess it. Had 2 do this same thing.
Oct 04, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerator problem
3 most common things that cause this are a defrost problem (will notice frost build up on back freezer panel), bad evaporator fan motor (should hear fan running in the freezer), or bad damper (vent to the fridge section). If no frost and fan is running check for air flow out of the vent. It should be at the top of the fridge section.
Oct 01, 2007 | Kenmore 93361
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
350 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
