Question about Garden
I can't get my ryobi 825r to start. I have
I can't get my ryobi 825r to start. I have removed and cleaned the spark plug but it doesn't appear to get any sort of spark when I attempt to start it.
Had the same problem. Take out your plug clean and regap.I got it started now but will not run on it's own lol. I will check it this weekend. good luck
Posted on Oct 20, 2009
  • 279 Answers
You can check the plug to see if it is firing. Remove the plug from the hole and connect it to the spark plug wire. Ground the plug to the body of the engine. (I use a jumper wire with alligator clips at each end) that way I can just hook it up. Once you know if you have spark, you can see if it runs or you have to check other things...Lee
Posted on Sep 05, 2009
Tip
Ryobi starting problems
If youtr ryobi petrol/oil mix machine will not start then check these out first.
1 . No spark change the plug but dont forget to check the plug gap.
2 . Still no spark change the HT lead
3 . Clean fuel/mix
4 . Lastly check the on/off switch for ware or rust and clean if ness
on Jul 29, 2010 | Garden
My trimmer is a Ryobi 825r and the flex cable is broke.
remove the head from the tube and pull it out
remove the tube from the motor end and pull the rest of the cable out
replace the cable and re assemble
take it to a mower shop for repairs
go to a junk shop and get a straight shaft and have no more problems
Sep 26, 2016 | Ryobi Garden
Blower wont start, spark plug dry. appears not to be getting gas
Did you try checking for spark by putting a screwdriver in the spark plug wire socket and holding it close to the end of the plug, while someone pulls the starter rope?
Jun 24, 2014 | Ryobi Garden
Very hard to start, i pull and pull and pull on the cord but it wont start i do prime it every third pull any ideas?
Chances are your carburator has dirt in it.
It doesn't take much to clog those little carbs.
Empty the gas tank and clean it.
Purchase a can of small engine carburator cleaner. Comes in a spray can for about $5 at Home Depot or Lowes.
Remove the carburator and disassemble it.
Soak the body in clean gasoline for about 15 minutes if you can agitate it do so to help the gas disolve any clogs.
Clean the ports with the spray cleaners to blow out any debris.
Reassemble and remount the carb.
Remove, clean and gap the spark plug
Refuel the gas tank with new clean gas
May 07, 2011 | Ryobi Garden
I have a Ryobi brushcutter that is 4 years old.When I was using it the other day it just would not run at full throttle. I checked spark plug,air filter and fuel filter. No adjustments on carb. I have no...
Smokey 2 cycle oil will cause the exhaust ports to carbon up and plug the spark arrestor.
Remove the muffler, use a pick to clean out the exhaust port on the engine, and the muffler inside opening, then clean the spark arrestor screen, to assure yourself you are correcting the problem start the machine up with the muffler off, it should run like a charm, if it goes back to running badly when you reattach the muffler it may be clogged on the inside.
Jun 14, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Ryobi Garden
Ryobi 33cc wont start
Assuming you still have evidence of fuel in the cylinder after carb work; and still have visible spark across the plug, I would install a new spark plug. It is fairly common for a spark plug to cease working under pressure in a cylinder while appearing ok outside of the engine.
Sep 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 825r 4 stroke grass trimmer fires momentarily then stops.
I would say try adjusting the carb screws further out,or start by winding all the way in then out 1,5 turns.
Mar 22, 2009 | Ryobi Garden
Garden Logo
547 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
