Question about Vacuums
My Sanitaire vacuum is not picking up well - works ok on floors but not on carpeting
  • 430 Answers
Depending on the model you may have a single or two motor system. If it is not running well in carpet mode but still has suction check to see if the brush for the carpet head is turning. If not look for a red reset switch or spin the brush when the vac is shut off. It it spins freely the belt is either broken or badly stretched and needs replacement.
Posted on Sep 06, 2009
Why does my eureka air speed vacuum not work when in floor mode?
There is an adjustment for carpet and for hard surfaces. Have switched it from carpet to a hard surface. When on carpet it sets up higher on a hard surface it should set lower. If it is to low it work properly either.
Oct 16, 2016 | Eureka Vacuums
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Mar 01, 2015 | Riccar Vacuums
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
How do i alter the dyson dc04 to use on hard floors
Hi there, it's Jack at Dyson.
If your DC04 has a brush control on the cleaner head, you'll need to set this to 'On' for carpets, and 'Off' for hard floors. You can find out how to do this on our Support site:
http://www.dyson.co.uk/support/dc04/dc04-brush-control/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-rotate-with-the-power-on
If your machine does not include the brush control, it will only be suitable for vacuuming carpeted surfaces and we'd advise against using it on hard floors in upright mode. However, you can use the hose and wand to vacuum hard floors and we have several suitable hard floor tools available which may help.
I hope this helps - if you'd like further advice you can reach our freephone Helpline on 0800 298 0298. Just to let you know, our Helpline is available from 7am-10pm, 7 days a week.
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.co.uk
Mar 06, 2013 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Does the vacuum lose suction when in the floor mode if the belt is broken?
To put it simply, no. By floor mode I'm assuming you're stopping the brush roll from turning so that you can clean hard surface floors instead of carpet. When the brush roll doesn't turn you do lose agitation which vibrates the carpet so that the dirt is more easily picked up by the vacuum. But you don't lose suction because the brush is not turning.
May 18, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
No suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Dec 29, 2009 | Riccar 8850 Vacuum
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Hello, I have a Eureka Sanitaire upright vacuum. It is not picking up as well it usual and I notice it no longer has that deep motor sound. What do you suggest?
Does there seem to be good air-flow and suction? If not, look for a blockage somewhere. Otherwise (and more likely because of what you say about the sound), look to the brush roller. Does it rotate when the machine's switched on? If so, maybe the bristles are worn and no longer make contact with the carpet properly. If not, the belt that drives the brush roller is broken and must be replaced. Your Owner Manual will tell you how to do this.  Good luck!
Jul 17, 2009 | Eureka Sanitaire Commercial SC785 Bagged...
Vacuums Logo
121 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
