Question about B&K Audio Players & Recorders
I need a volume control for a b&k avr305 can you help
  • boxhead53 Sep 05, 2009
    i want to replace the volume control on avr it is not workink. where can i buy parts
  • 3,230 Answers
Well you can  load BFD filters. But before you inserted a BFD between your AVR and sub you simply set up the balance between all your speakers and sub with the AVR trim controls and AVR test tones. Then your master volume of the AVR was your main volume control.
The situation hasn't changed much after inserting a BFD, other than you should not disturb the setting you set on the AVR sub trim because you may cause clipping or low level inputs into the BFD. So, use the subwoofers own amplifier volume to balance levels rather than the AVR sub trim.
Thanks
Posted on Sep 05, 2009
  • Mukesh Kumar Sep 05, 2009
    You can purchase your part from local dealer or order from the below link -
    http://www.bkcomp.com/support/
    Good Luck!!
Sony universal remote won't control the volume
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMVZ320 Try the above Sony web site, where they have support, or call a Sony Dealer. http://store.sony.com/-cms-page.sony.authorized.dealer.list?XID=M:accessories:esupport
Nov 17, 2013 | Sony RM-VZ320 Remote Control
Connected Emotiva mps1 power amp to Onkyo 875 and cannot control volume with master volume control knob, although can do so with Harmony controler.
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
May 01, 2008 | Audio Players & Recorders
Hi, I have HT-1001 mic, the volume from the mic is low, any possibility increase the volume? do i need to use the external Amp?
The mike can be a mismatch with your CB A booster mike amplifier with a volume control will suffice.
Oct 25, 2012 | Hisonic Audio Players & Recorders
For RM-YD023, I need to control my Receiver volume while in TV mode. I can control my Sony Receiver while in AMP mode, but cannot change independent volume control so that I can keep the remote in TV mode...
I contacted Sony support for this same concern. Their response was that there is no volume lock option, you must switch back and forth from "TV" to "AMP" :(
Jan 29, 2011 | Sony RM-YD023 Remote Control
Control the volume on each of the 12 bass shakers i plan to install
Please note that you can't simply wire them together in series or parallel. Connecting any more than 2 would likely cause damage to your amplifier. (depending on the impedance of the bass shaker 4 ohms, 8 ohms, etc.)
The Buttkicker brand recommends the following configuration for four buttkickers into one amp: Click here
As you can see, you need a combination of parallel and series connections to make sure the amp is "seeing" the correct load. I'd recommend purchasing three dedicated subwoofer amps (there are some good inexpensive ones at http://www.parts-express.com.
This will give you volume control over each set of four shakers at the amp itself. If you need control at each shaker, the only solution I know if is to use an impedance matching volume control.
Check Parts Express for those, too.
If this solved your problem, please rate it as FixYa. If not, let me know how else I can help you.
Apr 21, 2009 | Audio Players & Recorders
Carver stereo amp will only play
That should be normal. The main inputs usually go directly to the power amp. If you want volume control, put a mixer with faders beween them... Radio Shack used to have some inexpensive mixers.
Mar 09, 2009 | Carver PM950 Amplifier
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
I have a Sony TA FB940R (HiFi stereo amp) and the volume control reverts to the silent position, ie it rols back and won't stay put. As if a damper has been damaged or stopped working. Can you suggest a...
If you are tech guy then follow below technical instructions to fix your Amp problem.
Amp has motorized volume control and motor drive circuit has problem so motor rotates just one side (ends up volume) Below picture shows how is motor board and what drive IC is to power the volume motor.
You need to check voltages at pins and replace bad IC.
It is very simple circuit and easy to repair.
Good luck.
Oct 25, 2008 | Audio Players & Recorders
Rotel RA01 amp - volume control
Make sure you connected your record player in the right inputs. Better try it to a line level auxilliary input that is sure to pass the volume control. hope this helps..
Sep 18, 2008 | Rotel Audio Players & Recorders
Volume Control??
Unlike low-end hi-fi systems where you buy one box that does everything, the CD player you have is part of a component hi-fi system (i.e. you buy your CD player, tuner, amplifer etc. as separate items.) This is why there is no volume control. It needs to be connected to an amplifer. It's on the amp that you will find the volume control and where you connect the speakers. (When you connect it to your television, you are just using that amp in the TV instead.)
The CD player did originally ship with a remote control, but I don't know where you would be able to buy one on its own. You may find the the remote does allow you to alter the output level of the CD player, but you still need to connect it to a proper amp to get it to work.
Hope this helps,
Matt
Mar 27, 2008 | Technics SL-PD887 5-Disc CD Changer
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
