Question about Toshiba Estudio 200L Copier
We are getting a paper jam indicator, but cannot locate any paper jammed in the machine. The "call for service" light was on a few days ago. Could these two be related?
    Problem Solver:
  • 15 Answers
Yes, depending upon the make and model. I'd recommend that you call for service.
Posted on Sep 05, 2009
Machine code 5a
a 5a error code means that The machine does not work due to a paper jam or some sensor problem. here is a list of error codes for the dcp-j125 printer.
Error Code Cause Solution 30,31,32,33,34,35,36
37,38,39,3C,3F The machine does not work due to a paper jam. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) 40,42,43,44 The internal temperature is too high. Unplug the machine from the AC outlet and if possible cool the room where the machine is located. 46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us". 48 There is a problem on the print head, Please contact Brother Customer Service from "Contact Us". 49 The internal temperature is too low. Unplug the machine from the AC outlet and if possible warm the room where the machine is located. 4F There is a problem on the print head. Please contact Brother Customer Service from "Contact Us". 50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us". 8F There is a problem on the paper feed motor. Please contact Brother Customer Service from "Contact Us". A5,A6,A7,A8,AF There is a problem on the scanner. Please contact Brother Customer Service from "Contact Us". E2,E3 There is a problem on the main PCB. Please contact Brother Customer Service from "Contact Us".
Jan 07, 2014 | Office Equipment & Supplies
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
What does error 73 mean? the display keeps giving that error... i have a brother mfc490cw
It is my pleasure to guide you.
Quote
Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feed Problem.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us" http://www.brother-usa.com/support/CustServ.aspx.
FAQs & Troubleshooting http://welcome.solutions.brother.com/bsc/public/link.aspx?faqid=faq000495
UNQuote
Good luck and please post back that you are successful or that I can be more helpful.
Jun 09, 2011 | Brother MFC 490cw Color Inkjet...
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
I have a paper jam on a CLC 1120 and there is no paper jam I've check the machine 10 times
You didn't state where the jam is indicated. If it's indicating a paper pickup jam there are levers toward the back of the cassette that could get hung up.If it's a fuser jam the outlet lever on the fuser unit.If it's indicated in the transfer drum area a bad transfer sheet can give a false jam indication sensing paper on the drum.
May 25, 2010 | Canon CLC 1120 Color Copier
Have an Imagerunner 5180 giving err code E000007-0102 - Tried to clear it while in the service mode and it continues to give shutdown sceen - cant find anything physically wrong with the copier - Anyone...
Item Description Remarks AAA Indicates the numbers of jams
(larger the number, the more past the jam). 1 to 50 (50 max.) BBBB Indicates the date of occurrence. Month, day (2 digits each) CCCC Indicates the hour of occurrence. 24-hr notation DDDD Indicates the return of recovery. 24-hr notation E Indicates the location of occurrence. 0: copying machine
1: feeder
2: finisher
EFff Jam code. FF: jam type (T04-201-01)
ff: jam sensor (T04-201-02)
(For the feeder, T04-201-04.)
G Indicates the source of paper. (T04-201-03) HHHHHH IIIII Indicates paper size.
Mar 14, 2010 | Office Equipment & Supplies
I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Jan 11, 2010 | Canon imageRUNNER 2200
Paper Jam
Some basic non-tech questions:
  • Are you using paper that's been allowed to sit open for weeks? It might have absorbed water.
  • Are you in the habit of reusing paper that's double-fed? I used to, but it's more likely to jam
  • When was the last time the technician was in to do a preventive maintenance? The machine may need a basic clean-and-check.
  • Check your manual, and check what the machine is telling you (on the display, if it has one). The location of the jam may give you an idea of the reason for the jam (jamming at the fuser may indicate a cold fuser, jamming at the drum can be caused by broken separation fingers, etc.) If you have a technician, this will be useful information.
Nov 22, 2008 | Toshiba 2060 Copier
Fax fixable? error msg
We call the moose method of clearing paper jams, the RCMP method, cuz they only know how to shoot to kill. You did good. Except, there is no such thing as "Bending" anything. The term is "re-form."
Dec 21, 2007 | Brother IntelliFax-2820 Laser Fax
88 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
