Question about Sony Playstation 3 (PS3) Console
PS3 Power Surge Help!
I hooked my PS3 yo to my tv and plugged it into my wall. When I put the 3 cords into the TV, there was a loud pop, and smoke started to come out of the yellow cord jack on the tv. I think it was a power surge. I plug my PS3 into another outlet and it turns on and seems to work fine, however, there is no picture. Any ideas?
    Sergeant:
  • 338 Answers
Hi there try using the ps3 as audio-cd play(blind, without screen)
with any other tv to make sure soun still is coming...
if there was a flash or circuit destroyíng the yellow(video)plug,
either the cable has been destroyed or the short backfired even into the video module of the psx3.
try exchanging the cable, if that doesn't do any good, the video module got smoked...
let a technician repair/replace it or you think about becoming the happy owner of another brand new psx3
good luck!
Posted on Sep 05, 2009
Somebody hung my TV for me but, didn't put the power cord in so, I'm trying to navigate blindly, it's hung on the wall, to attempt to plug in my power cord but can't find it. Can you give...
Tries look near the square arm plate that have four screws holding the tv look for a hole with 3 steel prongs that ur tv a/c hole for power cord hook up.But if the tv it is very closed and hook up tight and flust to the wall will not able to hook up a/c power cord must take off wall to be able to hook up a/c power cord.
Aug 27, 2011 | LG 42LC2D 42 in. LCD HDTV
While watching my LG 55LW5600 this morning, loud popping sounds came from the TV followed by heavy smoke. What happened?
The tv power supply board,have blown capacitors components parts most likely.Don't tries to repair this power supply board though,because a loud poping sounds and heavy smoking have many more other components dies also just not easy to be seen as capacitors parts.The tv power supply board that the board,where the tv power a/c cord plug into it.Take the tv aparts.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 13, 2011 | LG 55 55LW5600 3D LCD TV
How do you set up a ps3?
I would suggest you follow these procedures, hook up your PlayStation 3 to a television. You must decide whether your TV supports high definitions (HD) resolution or not. For HD resolution, you must use a HDMI cable or a component video cable. These cables also support standard definition (SD) resolution. If you only have an SD television, you can use an S-video cable or an AV cable. These two can't support HD resolution.
Connect the PlayStation 3 to any audio equipment such as a A/V receiver or home entertainment system. Connect using a digital audio cable or, alternatively, run an HDMI cable to your A/V receiver then another HDMI cable to the television set.
Plug in the Ethernet cable, then connect the other end to a 10Base T jack from your home network. This connects you to the Internet and the world of online gaming.
Attach the AC power cord to the PlayStation 3, and then plug it into a surge protected wall outlet. Don't plug in the power cord until all other connections have been made as a chance of shock exists.
Perform the initial set up of the system. Turn on the power of the TV and game console, and follow the on-screen prompts. The pre-installed software guides you through the set up process.
Take care.
Jul 18, 2010 | Sony Playstation 3 (PS3) Console
I hooked my ps3 up to HD input now trying to hook it back up with tv/video input. Can not get a picture on the tv now. Any Help?
after you hook it up..unplug it for 10 secnds,then plug it back in and when you turn it on ,hold the power button down till you see somethng on the tv..a menu will pop up..
Feb 05, 2010 | Sony Playstation 3 (PS3) Console
TV will not power up, no lights blinking just a continuous beeping sound
Please follow the below troubleshooting steps: 1. If the Television is plugged into a surge protector, remove it from the surge protector and plug it directly into the wall outlet. 2. Try connecting the TV to a different AC wall outlet. 3. Try power resetting the TV. To Reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power ON the TV. 4. If the issue still persists, TV will require service.
Jan 23, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Does not turn on, light flashes, it clicks once, the remote control will not even turn the light on
Jan 21, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Surge protector shuts off while playing PS3
swap to another surge protector. if it still does it, it is a power surge at the outlet, if it does not, the Surge Proctector has worn out. have someone with the appropriate knowlege have a look at the outlet as well. older outlets especially tend to wear to the point where the plug literally falls out of the wall.
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
Ps3 blew up a 2nd tv
Make sure that you are not plugging either the game system or the TV into a surge supressor device or any other equipment that may allow you to have reversed the polarity of the AC current coming into the equipment from the wall outlet. Remember, most modern electronics equipment has a "hot" ground power supply. That means there is the possibility that you are sending current thru the ground return path of the items you connect in this way.
michtech
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
PS3 Sparks during hookup
u have a grounding issue with either ur cable or dish box,.and if u plug anything up to it it will spark adn shock and if u do it over and over it will fry the system,. hope this helps
Nov 19, 2008 | Sony Playstation 3 (PS3) Console
Vizio L32 HDTV - Blew Out, No Power
Yes, I do in home warranty work on vizeo, it sounds like you need a power board and perhaps a main board. The power board is what pooped.
Nov 13, 2008 | Vizio L32 32 in. LCD HDTV
Sony Playstation 3 (PS3) Console Logo
282 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
