Question about Manfrotto MagFiber 190MF4 Tripod
I have 486 RC2 ball head and a 190MF4 tripod. The ball head is not seated flush with the tripod and thus it wobbles. How can I adjust the ball head shaft to seat into the tripod?
4 Suggested Answers
  • 24 Answers
SOURCE: Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
Posted on Jan 30, 2009
  • 685 Answers
SOURCE: I am also missing the quick release for my Vivitar
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen. Because your tripod is not supported by the manufacturer; parts lists and pars are not available, you should measure the opening and see what other brand quick releases will work paying attention to the shape and locking mechanism. Otherwise just get another tripod.
Posted on Sep 23, 2010
  • 175 Answers
SOURCE: I can't get the ball head off my tripod. I've
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Posted on Dec 04, 2010
Friction control stuck
Send it to these guys for repair: http://www.manfrottotripodparts.com/repairs.html
There is a pretty hefty spring inside that will shoot out if you are not careful. Don't do it your self.
Jan 29, 2014 | Manfrotto 322 RC2 Grip Action Ball Head
Manfrotto 468MGRC2 manual
Jan 26, 2013 | Bogen manfrotto 468mgrc2 hydrostatic ball...
I dont know which head would fit my tripod
Most tripods have a standard screw on top. This allows users to mix&match tripods and heads. Thus, just about any head should fit your tripod. If you're not sure, take your tripod with you to a good camera shop and see if any of their heads fit. If one fits, it's a pretty good bet that the others will as well.
The choice of the type of head (pan-head or ball-joint), its weight, cost, and other factors are, of course, up to you.
Feb 11, 2012 | Photography
I am looking for advice on how to mount a Ball Head on the plate of a regular tripod, So far I have not found a Ball Head that has the same size thread in the bottom. Is an adapter available as a solution....
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Feb 20, 2011 | Photography
I cannot figure out how to get the plate off the head. I end up either putting camera on, then twisting the whole thing onto the tripod, or putting the head on the tripod and twisting the camera around to...
Sounds as if you haven't unlocked the quick disconnect plate from the 222 head.
Release the quick disconnect plate from the 222 pistol grip with the thumb release it will click open and pop the release plate up a bit to remove it. The affix this plate to the camera tripod socket 1/4 x20 female thread on the camera bottom. The underside of the quick release plate has a "D" ring to screw it to the camera, fold over the "D" ring and when you pit it back on the 222 set the edge under the lip and set it down the brass pin then will snap the thumb release over and lock into place.
See my diagrams
And the release plate
Jan 22, 2011 | Manfrotto 222 GripAction Ball Joystick...
The water leak to the bowl. How to fix? Thanks.
This usually indicates one of two things: (1) a poorly seated flush valve ball, which can be easily adjustedor replaced, or (2) a flush handle chain that is too long and is getting caught between the flush valve ball and the seat, which is easily remedied by shortening the chain between the flush handle and the flush ball.
One other possibilty is that the fill valve is not shutting off the bowl wash function. There is a small adjustment screw for regulating the flow.
Dec 11, 2010 | Home
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
The flow of water into the bowl does not stop after the toilet is flushed.
Nov 23, 2010 | Eljer Home
Found a manfrotto tripod model # 190xprob and am looking for instruction manual
Try this:
: pentadictos.files.wordpress.com/2008/09/055xprob-190xprob.pdf
Jan 03, 2010 | Manfrotto MagFiber 190MF4 Tripod
May 06, 2008 | Manfrotto MagFiber 190MF4 Tripod
Manfrotto MagFiber 190MF4 Tripod Logo
49 people viewed this question
Top Manfrotto Photography Experts
Mitch Davis
Mitch Davis
ray gallant
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
