Question about Mitsubishi WS-55809 55" Rear Projection Television
It is a toshiba 57h81 and i would like location of vidio board
The picture is scrambled until it warms up i have heard it has bad solder caps.
    Sergeant:
    Champion:
  • 298 Answers
Check this site for the solution
Read down basically it a heat
and esr problem with capacitors
also check here
for the tools etc you
may need if you are going
to do this yourself
Posted on Dec 08, 2007
Horizontal lines on toshiba 57H84 television until warms up
Set will have a "HYPER" BOARD causing this issue----there was a service bulletin with a photo of the board with 10 surface mounted filter caps that dry out and need to be replaced.
The failing caps tend to begin to regain capacitance when hot---gradually the wait gets longer and longer.
Board no longer available from Toshiba so 3 choices: replace the caps yourself (tricky and not easy) or have it sent for rebuilt to PTS electronics (about 200) or go shopping for a new set and retire this one.
Oct 31, 2012 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h81 location of vidio baord
yes they are bad, they are surface mount on the digital board. Board replacement is advised. They are not easy to change if trying to replace the capacitors.
Dec 08, 2007 | Toshiba 57H81 57" Rear Projection...
Location of convergence chips in Toshiba 57H81.
hello if you can use a soldering iron you shouldn't have any problems but you will need to test the resistor in front of the ic and the capacitors at either end of the ic ! the ic usually located to the right hand side of the tv behind the tuner board connected to metal frame called a heatsink 2 big black chip good luck
regards
shaun
Mar 27, 2010 | Toshiba 57H81 57" Rear Projection...
Toshiba Projection Television Problems
we are facing server problems please reply to me at coolguy4u_008@yahoo.com
don't worry i have found your part..
Apr 11, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h81 location of hyper board and remove procedure
Hyper board is located directly behind the input board, this is where all the tv conections are, then they are two tabs soldered from the bottom of the board then it simply unplugs, But replacing all those capacitors on that board can be a little tricky, replace all 10up @16volt caps and that usaly repairs the board
Feb 12, 2008 | Toshiba 57H81 57" Rear Projection...
Distorted Picture Upon Startup
You have a bad capacitor in your power supply.
Dec 22, 2007 | Toshiba 57H81 57" Rear Projection...
Picture Jumps/flashes for first 5 minutes
There is a module called a hyper board that is vertically mounted near the jack panel. Inside the module are 10mf/25v capacitors they are grtting weak. The module is fully shielded and pluggs into a socket. the module has 4 tabs (2 on each end) that must be unsoldered before it can be unplugged. This repair should be done by a qualified technician. The caps are surface mounts and very small. Unless you have excellent soldering skills and a rock steady hand DO NOT ATTEMPT to repair this problem on your own.
Nov 16, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 picture bounces. Can't tell if horiz. or vertical.
Unstable picture, wavy, jittery, and loss of sync are a symptom of bad capacitors in the hyper module. The problem is worse when the set is cold, but when warm the sympton gets less or goes away. In the latter stages the problem never gets better even after the set has been on for hours. There are about 6 surface mounted caps (10mf/16) inside the shielded Hyper module. The module is vertically mounted behind the jack panel and can be unplugged from its socket after unsoldering the 4 anchor tabs on the bottom side of the PCB. This type of repair should be made by a qualified technician do to the complexity of chassis removal and expert soldering skills.
Oct 25, 2007 | Toshiba 57H81 57" Rear Projection...
I had the same problem and followed the instructions from Jack and my 57h81 is bak up and running. Thanks Jack. RonD
Jul 02, 2007 | Toshiba 36HF72 36" TV
No picture but have sound
Toshiba 57H81 57 in. Rear Projection Television Go to above under solution for tip on fixing your problem.
Jun 22, 2007 | Toshiba TP50H50 50" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
