Question about Blaupunkt PCA250 Car Audio Amplifier
Factory stero to amp
How do i hook up a amp to a factroy stero
  • 65 Answers
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Posted on Dec 09, 2007
  • Blaupunkt Master
  • 637 Answers
If the amp has high level inputs then you run the speaker wires directly to the amplifier. If not you would have to get a line level converter also known as a high low 2 convert speaker wires to RCA at that point you connect an RCA cable.
Posted on Nov 21, 2014
My tablet does not fo nothing after press power on it just frozen
Try to factory reset your unspecified tablet. Search Google hoe to do factory reset lookng for terms
Sep 29, 2015 | Tablets & eReaders
Do the factory amp have a fuse
Yes, there is one in engine compartment, it's in a yellow holster inside fuse box, also one on driver side left side of dash, take off the panel and it should have diagram.
Feb 15, 2015 | 2002 Mitsubishi Eclipse
I am haveing problems hooking up my stero none of the speackers are working i hook every one of them up and still no sound
Did this unit suffer through a lightening/thunder storm of late? It would appear that your left and right stereo amps are burned out.
Aug 25, 2011 | Audio Players & Recorders
If your radio shuts off with the key and you use the power ant. or the amp turn on wire for your amp when your radio shuts off so will your amps. If your radio is wired constant hot you need to change the red wire on your radio to a key hot.
Aug 20, 2010 | Car Audio & Video
Had dead battery in 2002 honda civic got jump now word CODE in radio display
try disconecting the positive terminal of the batery for sevral minets (5-10) this will reset the brain box memory for the stero aswell as for the car it self.
what caused the batery to go dead in the first place?
things that i can think of :
1) left headlights on over night
2) bad altenator not charging batery
3) battery is old and not taking a charge anymore
4) new stero installed incorectly and drainging the batery
have you resently installed a new stero or amplifyer?
is the turn key igntion system hooked into the amp/stero antena lead so that thy are shut of when the ignition is?
of note: new streo >theres a blue wire marked ant that goes to the amplifyer if not there you need to find the orange accsesory wire coming from the turn key igntion>check for power when ignition is in the on & off states could be yellow in some cars but is usaly orange if this wire has on and of state controled by the turn key igntion this would be the wire to tap into for the amplyfire and the radio main power
check your radio's instaltion guide for code errors
its posible that when hooking up the jump it was done incorectly and blew up the radio
ie postive and negative where fliped
hope this helped :)
Feb 24, 2010 | 2002 Honda Civic
Hooking laptop to onkyo sr604 through hdmi no sound through stero
hdmi is video only
you will need to use the rca/phono inputs for audio.
you will need a stereo mini jack to steroe rca/phono
use the i/p marked aux/cd/
make sure the volume on the onkyo is turned DOWN before connecting any new input source.
The output from most laptops is designed for headphones so you may need to adjust the volume on the laptop DOWN as well.
Perhaps start off with laptop at 30% and the amp DOWN then increase the amp until you can hear the laptop sound.
To get good quality audio from a laptop you would be beter off with a USB sound card.
hope this helps, thanks for using FixYa
if this is helping please vote.
Feb 20, 2010 | Onkyo TX-SR605 Receiver
Can not get power to radio
Have you got an Aftermarket Harness to Connect to the Factory Harness that is inside the Dash for this Install????
Jan 30, 2009 | Pioneer DEH-1400 CD Player
Radio prob
is it a factory or aftermarket stereo system. if it is an aftermarkek system you are going to have to run your own fused power source from the battery to the amp
Jan 04, 2009 | 1995 Jeep Grand Cherokee
Stero installation
need wiring harness clip and install kit. It is pretty easy after that if you aren't installing amp or subs. what is your question, how to get factory radio out?
Aug 31, 2008 | Pioneer DEH-1600 CD Player
Blaupunkt PCA250 Car Audio Amplifier Logo
305 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
