Question about Panasonic CT-32HXC43 32" TV
Panasonic #ct32hc43g; no power when power button pushed(yes its' plugged in and the plug works fine with other electic items )
  • 178 Answers
There are many causes for this set to have no power, if you get no red light at all a common fault is the 6.3 amp main fuse blowing in this set. It is because the timing unit for the degaussing coil has changed over time and is staying on just a little to long causing the fuse to blow. A technician will put a 7 amp fuse in as a replacement, Do not use a fuse of any higher value or you will have a fire hazard. If the 7 amp fuse blows then you either have another power related issue or the timming unit has gone way out of tolarance and need changed.
If you have no experience inside of a tv, and don't understand the hazards of electrical shock even with the tv unplugged i would not attempt to open the set up and do this yourself.
A service call from a technician could run around $100.00.
Posted on Sep 05, 2009
My blue power light is on but tv will not come on.and cant power the tv off
Try unplugging the tv from the wall for 5 or so minutes. Plug it back in and turn it on. If it works, fine...if not then look for a small hole marked "reset". Put a straightened paper clip in it and push slightly until you feel the button. Push and hold for 30 seconds and let go. See if that doesn't fix it.
Jan 04, 2014 | Panasonic VIERA Televison & Video
Cannot start
IS IT GAS OR ELECT?MAKE SURE PROPER FUEL OIL MIXS IS CORRECT//CHANGE OR CLEAN SPRK PLUG WITH SMALL WIRE BRUSH,CAREFULL NOT TO PUSH TOO HARD DOWN CAUSEING SPRK PLUG GAP TO CLOSE!!IF ELECT CHECK ELECT CORD MIGHT HAVE BURNED OUT WIRES INSIDE PLUG,OR SWICH MIGHT HAVE WORN OFF INSIDE CONNECTION..
May 25, 2013 | kawasaki Garden
Put in all the ingredients and presssed the start button counting down but nothing is happening
More details would help troubleshooting. For example, are you sure the machine has power (is the LCD display working? Is the light above the on off push button on?). The circuit breaker for the outlet it's plugged into (it is plugged in fully, right?) may have tripped, for example.
May 30, 2011 | Panasonic SD-YD205 Bread Maker
F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
Jul 17, 2010 | Panasonic DMR-E85H DVD Recorder
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
Television will not come on. Power light flashing red.
Hello Debbie ok the problem that your tv set is having is coming from the convergence board which is faulty and has to be replaced, you can find one at partstore.com or by contacting the manufactuer of the tv set they should have one in stock, change out the board and you should be seeing tv in no time thank you hope this helps.
Aug 27, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My AcerAspire 5920 laptop won't turn on. It is plugged in. When I push the power button, nothing. No lights, no sounds, no action. It worked fine yesterday! What happened? How can I fix it?
Sir,
Unplug the power
Take out the battery
Wait 2 minutes
Put the battery back in
Try to turn on the machine
If that doesn't work, take out the battery
wait 1 minute
Plug in the latop and try to see if you can turn it on after that.
If that doesn't work, then yes it's something else
However try to hold the power on key down for 10 -15 seconds. If that does nothing take the battery out and use only the power adapter.
Thanks Good Luck
Aug 09, 2009 | Acer Aspire 5920-6335 Laptop
Fax machine won't power up
Try pushing the power cord firmly into the back of the machine
Jun 22, 2009 | Panasonic KX-FM220 Plain Paper Thermal Fax
Generator will not produce electric power
Check the air cleaner to make sure that it isn't clogged with oil. If you find any significant amount of oil you may also need to clean the carb. Also check the spark plugs for fouling. Once you're convinced that the engine has no service related issues, check the governed throttle setting. To do this find the spring that pulls on the governor arm and look for either a tab to bend up or a threaded rod to tighten at the end of the spring not connected to the governor arm.
Regards,
Carl
Feb 10, 2009 | Coleman Powermate Powermate 5000W...
Panasonic CT-32HXC43 32" TV Logo
223 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
