Question about UltraLast ULAC3660L For Acer Aspire 3660/3680/5600 Series
Acer TravelMate Laptop, cord getting hot, not getting power
I have an Acer TravelMate Laptop. When I plug it in, the light on the cord lights up normally, but the computer often does not recognize it. Sometimes it will say it's plugged in, but won't charge, and sometime it won't even say it's plugged in. Sometimes the cord (where it goes into the computer) will get really hot, and the plastic on the tip of the plug where it goes into the computer is looking dark and a little melted.
  • contraclar20 Sep 22, 2009
    I bought a completely new power cord (the whole thing), but the same problem persists. :(
    President:
  • 2,600 Answers
I would imagine the voltage regulator in the adapter brick it dying...it will fry your motherboard if it starts throwing off power spikes. laptops need good consistent power flow of the right voltage. Buy another adapter.
Posted on Sep 05, 2009
Acer travelmate c110ti will not charge
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 11, 2012 | Acer TravelMate C110Ti Laptop Charger...
Power button is not working travelmate270
Give us more details? What do you mean Not Working? Are you saying that when you press the Power Button, nothing whatsoever happens?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 06, 2012 | Acer TravelMate 2702WLMi Notebook
I have an Acer Aspire one NAV50 travelmate adapter but I don't have a plug. Is there anyway I can get the plug separately?
Are you talking about the cord that goes from the adapter to the wall? If so, any electronics supply store like Radio Shack should be able to source it. If not you can try DIGIKEY.com.
Mar 15, 2011 | Acer Aspire One 521 532H 533 D260 NAV50...
Power up issue
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Nov 20, 2009 | Acer Computers & Internet
How do I have an Acer Travelmate 4060 series repaired? When the power cord is inserted into the laptop, the inside unit must be lose or broken because after it loads and while using the laptop the screen...
If I remember correctly, PC World have a door to door collection repair service, any pc repaired for a set price. Courier supplies the packaging.
If you are a DIY er, Nope. it can be done ,just a little fiddly.
Just remember to clear any sensitive material.
Nov 15, 2009 | Acer TravelMate 2300 Notebook
Travelmate 4150 not able to find the battery
you can also use your laptop without the battery, just plug its power cord while using for the mean time, the battery may be has low charge to the point that it can't turn on your laptop, insert your battery then plugin your power cord to charge your battery
Oct 19, 2009 | Acer TravelMate 4150LCi Notebook
Travelmate only powers up with battery inserted. But AC still charges battery. Orange light goes on and of
Sorry to tell you this but you may have a problem with the charging system. That will require you to return it to Acer or an Acer service center. You can also try this. I got this from Acers' travelmate support website:
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
You can aslo google your specific model of Travelmate to see if others are having this issue.
Les
Jun 27, 2009 | Acer Computers & Internet
The laptop does not power on
I think we have a case of fried PowerSupply, test the voltage output witha multimeter, check the output printed on the brick. if that is OK then U have a Bad Motherboard.
you will need to replace it.
Jan 29, 2008 | Acer TravelMate 2413LMi Notebook
Acer Aspire 3500 not turning on
Do you get any thing? Lights, indicators, sounds?
Ron-
Nov 08, 2007 | Computers & Internet
Travelmate will not boot up
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
Feb 08, 2007 | Acer TravelMate C112TCi-SP2 Tablet PC
UltraLast ULAC3660L For Acer Aspire 3660/3680/5600 Series Logo
145 people viewed this question
Top UltraLast Computers & Internet Experts
David Payne
David Payne
Are you an UltraLast Computer and Internet Expert? Answer questions, earn points and help others
