Home | Kenmore | 54351 Dehumidifier | Power but doesn't run
Kenmore 54351 Dehumidifier
Problem for Kenmore 54351 Dehumidifier
By lsm409 on Sep 05, 2009
Ordered main circuit board, replaced and still doesn't work. I have worked with and repaired eletrical and electronics, but the only thing I am sort of lost at is the humidity sensor. Don't know if it is possible to check or bypass to see if the unit will run. Also is it possible to return the main circuit board for credit since it was not the problem. Thank you. Email is lsm409@sssnet.com
Clarification Request
Posted by beaman2202 on Oct 09, 2009
I have a LG LHD30 and I think your unit used the same controller EBR39204301. There was another string under the my humidifier that talked about the humidity sensor as a possible failure. Is this the same controller?
Solution #1
posted on Sep 05, 2009
Somewhat Helpful)
A_HVAC
Rank: Wiz
Rating: 85%, 45 votes
check may the stpdown transformer is out or the fuse or sensers and before check the remote settings
Was this helpful?
Yes
No
Popular Solutions for Kenmore 54351 Dehumidifier
Questions and Unsolved Problems for Kenmore 54351 Dehumidifier
Do you recommend Kenmore 54351 Dehumidifier?
Answer
Answer
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running.... (More)
Answer
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change... (More)
Answer
i have a kenmore and it frost over all the time when it running.
Answer
Kenmore dehumidifier model 580-54351400- replaced fan motor but overheaqts and does not collect... (More)
Answer
ran fine for a couple of weeks. emptied bucket several times. Then would not start for several days.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 54351 Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
