Question about Optics
I removed the 5 hex screws and that loosens the base cover but something else is holding the cover on. I have to remove and replace the GPS chip on the motherboard which is under the base cover. Thanks! Mike Reed
  • 3,230 Answers
Well may be there are 2 or 4 plastic locks on your Binocular, see outside of that binocular the plastic locks are seen on the outer surface and to open them you need to push them using a screw driver.
provide me the model number if you need more help....
Thanks
Posted on Sep 05, 2009
HOW TO REMOVE FAN FORCED ELEMENT
All I needed was a phillips screw driver, a small hex socket drive and an 8mm wrench.
1. Turn off the mains at the switch board. There might be a switch near the oven or stove too, turn that off as well. Check that the power is off!
2. Remove the screws holding the oven to the cupboards. Mine was held in by 4 timber screws on the edge.
3. Slide the oven out of the wall. I used a small table to support it.
4. Remove the hex drive screws that hold the top lid on.
5. Using a trusted multimeter CHECK THAT POWER IS OFF! There are now exposed power terminals.
6. Undo the supply power terminals and remove the cable. I taped mine up.
7. Remove the back cover - more hex screws.
8. Pull the spade terminals off the heater element.
8. Inside the oven remove the shelves and side racks. They pop off the wall.
9. Pull the rear fan shield towards you. It should pop out at the top and then lift off 2 small tabs.
10. Remove the phillips screw at the bottom of the heater element.
11. Remove the 2 spring clips.
12. The element can now slide down and towards you.
13. Replace the element and put it all back together in reverse order.
Oct 08, 2014 | Ovens
Oil leak on poulan snow lower
follow this steps and fix it. God bless you
  • Remove the hex bolts holding the plastic leaf blower housing in place with your hex wrench. You may wish to cut the cord with your scissors and loosen the bolt or screw securing the rope assembly with your hex wrench or screwdriver.
  • 2 Remove the spring assembly carefully. Do not remove the spring, only remove the assembly.
  • 3 Remove the old cord from the leaf blower pull cord assembly by gently pulling it away from the assembly with your hands. Notice the direction the pull cord is wound, as this becomes important in the next step.
  • 4 Wind the new pull cord in the same direction you removed it in Step 3. Make sure the inner end of the pull cord secures in the faster or slot provided on the pull cord assembly. This varies depending on the leaf blower manufacturer.
  • 5 Replace the pull cord pulley and place over the spring. This is the white plastic spool.
  • 6 Rotate the pull cord assembly two or three times in the same direction the cord pulls wearing safety goggles and work gloves. Reinsert the center screw by screwing it in place with your screwdriver; this holds the pulley assembly together
  • 7 Insert the leaf blowers cord end into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new pull cord; this prevents the handle from being pulled off the pull cord while you start the leaf blower.
  • 8 Place the pull cord assembly back onto your leaf blower in its designated area and secure by refastening the four hex nuts with your hex wrench.
  • 9 Replace the housing cover of the leaf blower and refasten the hex nuts with your hex wrench. You removed the housing cover in Step 1.
Nov 24, 2013 | Garden
Replace clutch cable
In the middle of the clutch cable under a rubber boot is the adjustment for the cable. Slide this down to access the adjuster. This may take a little effort to do. Use a 1/2 inch wrench to hold the adjuster and a 9/16 to loosen the lock nut. Turn the lock nut and adjuster all the way to the top. Remove the retaining ring on the underside of hand control and remove pin. Remove clutch lever. Slide out the pin holding the clutch cable in place. Remove derby cover, the large round cover where the cable enters buy removing the four hex screws. Remove spring with attached hex lock plate. Use a flat head screw driver to turn adjusting screw clockwise to release ramp and coupling mechanism. it should move forward and make the cable slack enough to remove it. Unscrew nut from adjusting screw, remove the cable end from small slotted end of coupler. Unscrew the cable from primary cover.
Screw the new cable in to the cover, reconnect cable to the coupler. Leave derby cover off and re-install everything, except spring and hex plate. Turn the clutch adjusting screw counter-clockwise until resistance is felt, then back-off 1/4 turn. Re-install spring and hex plate, you may have to wiggle the hex nut a bit to get everything to line up. Replace the derby cover. Turn adjuster on the cable down until there is about 1/16 free play at clutch handle. Tighten the adjuster lock nut. Slide the protective boot back over the cable adjuster. I recommend using zip ties to seal the boot. Place a zip tie at the bottom of the boot first. Then using some WD-40, insert the straw a good bit in to the top of the boot. Spray slowly until foam starts coming out the top. Seal the top of the boot with a zip tie. This will keep the adjuster from rusting. That's it your done.
Feb 15, 2013 | 2001 Harley Davidson XLH Sportster 883...
REFRIGERATOR AND FREEZER NOT GETTING COLD. ERROR CODE 5Y.MODEL NUMBER LGUS2642LF2 SERIAL NUMBER 4A23305873
That error code is "SY" and not "5Y" and it is for the evaporator sensor error. You will need to replace the sensor.Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Access the evaporator assembly cover in the rear of the freezer section. In convertible units that can function either as refrigerators or freezers, and is located toward the bottom of the unit on the inner back wall -- if necessary, remove the two lower glass shelves and the crisper compartments.
Remove the screws securing the evaporator cover to the freezer wall, using a Phillips screwdriver.
Pull the evaporator cover away from the wall just enough to access the electrical connection behind the cover. Be careful not to damage the gaskets on either side of the evaporator cover. Reach behind the cover and disconnect the electrical connection from its wiring harness. Remove the evaporator cover from the freezer.
Remove the wires inside the exposed evaporator assembly from their retaining clips, then squeeze the quick-connect mechanism to detach the wires from the fan motor.
Remove the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using a 5/16-inch socket or nut driver.
Remove the two hex-head screws holding the fan motor to the mounting bracket, using the 5/16-inch socket or nut driver, then pull the fan blade off the motor shaft.
Examine the fan to make sure the blades are not damaged; if necessary, replace the fan itself as well as the motor. Slide the fan onto the motor shaft.
Attach the new motor to the mounting bracket, using the 5/16-inch socket or nut driver to secure the two hex-head screws.
Replace and tighten the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using the 5/16-inch socket or nut driver.
Reattach the the fan motor wires by clipping them back into the quick-connect mechanism, and set the wires back into their retaining clips in the same manner as they were attached.
Set the evaporator assembly cover back into place, then reach behind and connect the electrical connection into the wiring harness.
Secure the Phillips screws that hold the evaporator cover to the freezer wall.
Replace the shelves and crisper compartments if they were removed, then plug the refrigerator into its power source and verify proper operation.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Refrigerators
Broken pull cord
How to replace a broken pull cord on a leaf blower.
1) Remove Hex bolts holding plastic leaf blower housing in place with your hex wrench. you may want to cut the cord with scissors and loosen the bolt or screw securing the rope assemble with hex wrench or screwdriver.
2) Remove spring assembly Carefully. (DO NOT REMOVE THE SPRING ONLY REMOVE THE ASSEMBLY)
3) Remove old cord. Notice the direction the pull cord is wound. This is important in the following step
4) Wind new pull cord in the same direction you removed it, as in step 3, Make sure cord secures in the slot provided on pull and assembly.
5) Replace the pull cord pulley and place over spring.(This is the white plastic spool.)
6) Rotate the pull cord assembly 2 or 3 times in the same direction the cord pulls. (wearing safety goggles and work gloves) Reinsert the center screw by securing in in place with your screwdriver.
7) Insert the leaf blower cord into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new cord.
8) Place the pull cord assembly back onto your blower in its designated area then secure by refastening the 4 hex nuts.
9) Replace the housing cover of blower and refasten the hex nuts.(the housing you removed in step 1.)
I hope this was some help to you. Good luck.
Jul 01, 2012 | Homelite Consumer Products Backpack...
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
How do you lock spindle on Delta Osillating sander to change sand rolls?
The spindle screw is reverse tread and you need to turn it clockwise to loosen and counter clockwise to tighten the screw. You can usually hold the spindle with your hand then turn the screw clockwise to loosen the screw. Worst case scenario, carefully turn the machine upside down. Place it on a clean supporting surface. Use a flat-head screwdriver or similar device to remove the plastic gear cover to gain access to socket-head screw. Carefully place the machine on its side. Attach the spindle adapter to the motor shaft turning the spindle adapter counter-clockwise on the shaft.
NOTE: Motor shaft has a left-hand thread.
Place a 7/16" open-end wrench on the flats of spindle adapter. Insert a 3/16" hex
wrench into the socket-head screw located where the plastic gear cover was removed.
Hold the hex wrench to prevent the motor shaft from turning. Turn the wrench counter -clock wise to
fasten the spindle adapter on the motor shaft.
Reinstall the plastic gear cover that was removed above.
Jul 10, 2010 | Garden
Ignition switch
1. Disconnect battery.
2. Remove airbag, two hex/torx/or philips head screws in the back of the bag holding it in.
3. Remove wheel. 24mm socket required for this. This is expose the clock spring area. Inspect that.
4. Remove top steering column cover. Two philips screws holding in under the bottom cover. Top cover comes off. The wiring for the horn is in there as well.
5. Remove instrument cluster. Two screws holding that in. Have a flat head handy as well to aid in unplugging the connectors for the cluster.
6. You will see the ignition switch to your right and the harness. Put key in ignition, remove harness, just unplugs. How there will be two small screws holding in the switch. Often, if the switch has never been replaced, they will be covered by a red paint. Take a small philips screw driver and loosen the two screws, no need to remove em. Ignition switch should just slide out.
7. Have new switch handy. No more than $40 even from dealer. Slide switch in. Its good to remember the way the old one came out. Screw down switch, plug in harness.
8. Install the cluster, column cover, and wheel in reverse order from above.
Jun 18, 2009 | 1991 Audi Quattro
Repair of 1939 Toastmaster Toaster Model 1b6
remove bottom plate.....remove 10 screws holding the bottom brown plastic base...loosen screw under push down lever....romove light, dark knob small center hex screw....cover will now lift off....gently....watch #20 toast "wires"
May 04, 2009 | Kitchen Appliances - Others
I have a 1998 lincoln with a damaged rearview mirror and I don't know how to remove and reattach a new one. How do you get the replacement mirror to release the slide in metal part that holds in the...
under the mirror there is an allen screw. you will need a allen wrench to loosen it to remove the old and install the new. make sure you loosen to the left and tighten to the right. good luck.
Feb 24, 2009 | 2003 Ford Windstar
Optics Logo
18 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
