Question about Kicker KX600.1 Car Audio Amplifier
Subwoofers dont bump
I have your typical subwoofer system in my car but they dont bump, amp is good and rca are good aswellas the woofers everything seems to be fine new radio just installed
    Guru:
  • 1,326 Answers
No such thing as a typical sub system. Be more specific? If the subs are moving well and just not basing you will need to check 2 things first. Try the polatity of the speakers (reverse one) they may be out of phase and will cause the bass to cancel eachother. Another cause is the box may the incorrect size for the speakers and will not give you the correct sound the speakers are capable of. If neither of those work check your amp settings and make sure its set on sub/low frequency.
Posted on Sep 07, 2009
Hi i purchased the bnps102 woofers and used them for 2 weeks i really enjoyed them and i also purchased the pyle 1400 watt amp and a jvc deck along with the boss amp kit installation now the speakers about...
If the lights on your sub box aren't coming on it's either your ground of power wire came loose or the transformer blew. As for the subs, make sure all the connections are good, especially on your RCA wires. If your amp is getting power, then check your speaker connections. Also, make sure to turn the gain know up. The gain knob is located next to the RCA input on the amp. Let me know if this helps.
Aug 21, 2011 | Pyramid BNPS102 Car Subwoofer
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
Dear Sir, I hav dell vostro 1015 laptop with windows Xp Operating system. I have purchased 4.1 subwoofer system. When i am connecting subwoofer to pc audio output & all 4 speakers to back of...
Recheck your wiring and instructions. If your woofer is self powered perhaps the amp is no good. Actually it better have amps since the laptop output will not power those speakers.
Mar 31, 2017 | Computers & Internet
NEED TO KNOW HOW TO HOOK UP SUBWOOFER TO RECEIVER
Hi and welcome to FixYa,
Offhand, most receivers do not have a built-in sub-amp but do have a line level sub woofer out. What is then required is an active subwoofer or an additional mono amp for the subwoofer speaker. The receiver will then be connected through an RCA to RCA cable and the subwoofer speaker connected to the add-on amp.
Good luck and thank you for asking FixYa.
Aug 15, 2009 | Pioneer Audio Players & Recorders
Which jacks to wire the subwoofer to?
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
Good Luck,
BB
May 16, 2009 | Kenwood Audio Players & Recorders
Could a ground stop your woofer from working?
First check the speaker wire from the amp to the sub, see if it's connected right. Second check the rca cables that goes from your amp to the back of the deck. I f both wires are still connected fine try to replace the rca cables. If it still doesn't work the rear out put at the back of your deck, where the rca's are connected are bad. FYI deck is bad.
Nov 29, 2008 | Jl Audio 12W3 Car Subwoofer
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Subwoofer stop working
push down on the speaker, does it make a ruff nosie? if so the speakers voice coil is blowin. did ya check the amp to the subs?
could be a lot of things . check the amp make sure it has power,
do u have an in line fuse? if so check that ,to make sure it aint blowin
May 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker KX600.1 Car Audio Amplifier Logo
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
