Question about Apple iPhone 3G
Et me explain what my problem is.. I executes Downloaded code first time Video runs perfectly without any blinking (smooth playing) I press done button on top-left corner of media player. ok video is stopped now. Now I again start video play Video isn't playing as good as previously. There is some problem in video playing. Now, I have implemented the same code - for playing video - in my application. Let me know, Where am I making mistakes? Thanks in advance for your humble help to me.
Similar to other 'askers'. I have a XV-DV323. It plays CDs and compiled video discs perfectly, but shows 'No Disc' when attempting to play original DVDs. I've already done the factory reset several times...
When a player stops working with disks you can always check out firmware but in all likelihood your laser assembly has lost its ability to focus on a particular type of disk. Repair not cost effective and yo may have to go shopping.
Jun 19, 2017 | Pioneer DCS-323 System
Tip
How to program an rca universal remote without codes
If you have a universal remote but dont have the codes or the codes dont work then what you can try is to scan all the frequencys using the remote to manually scan to work for your telly or other equipment your trying to control.
Follow these simple instructions
1. Turn on the device you want the control to control ie the tv or dvd or stereo etc
2. You need to now press and hold the button for the device you want to control and also the power button untill the light on the remote stays on( for this case we are going to program it to control a tv) so press and hold the tv button and power button hold them down untill the light stays on
3. press the play button once every 5 seconds( a bank of 10 codes is being sent every time you press the play button)
4. when it turns the tv off wait press the rewind/reverse button and check it turns the telly back on if it does then you need to hold the stop button untill the light goes off.
Once you have done this check the remote is working properly ie changing channels ets if it dont work properly then follow the instructions again and try again you may need to do this a few times till it gets the right signal
on Jan 18, 2010 | Televison & Video
Pare feu 9339
Demarrez votre PC et appuyez sur F8 a plusieurs reprises jusqu'a ce que le menu de demarrage est en place. Ensuite, selectionnez "Mode sans echec avec reseau". Maintenant obtenir tout ou partie des programmes gratuitement ci-dessous.
Telecharger, installer et executer Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
Lors de l'installation de choisir la version non-pro.
Telechargez, decompressez, installez et lancez TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Telecharger, installer et executer Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
Si vous avez un tres vieil anti-virus, puis telecharger, installer et executer Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Veillez a selectionner tous les "categories de menaces lorsque vous installez ou configurez Avira ...
Vous devriez etre en assez bonne forme si vous executer et installer tous ces programmes.
Jul 29, 2012 | Zynga Texas HoldEm Poker
First I downloaded IGI 2 from torrentz.after i installed IGI 2 and when i trying to play they ask please insert disk 1 select ok and restart application.this is a downloaded game. therefore i dont have...
This is because the game has not been cracked. Usually in the torrent file there should be a crack for the game. You have to run this crack to enable you play the game. Check the downloaded folder and there should be a folder or an executable file there which can be used to crack it. Take a look at it and run this file. After running this file it should work properly without asking for any disc.
Hope this solution has been helpful?
Jun 20, 2011 | Computers & Internet
In a pc tablet MID 7003 with os ver 1.8.2 , internet connection ok, when playing recorded YouTube video(downloaded) a message appears on screen "delete vdeo?" instead of expected "play video...
If this is the first time that you are trying to do this, this is most probably an issue with the video codec. If you are using windows media player to play the you tube downloaded video you download and install video code.
Here's a link of the video codec that I'm using and it works perfect.
http://www.codecguide.com/download_k-lite_codec_pack_mega.htm
Hope that woks for you.
I'll appreciate the feedback.
Thanks.
-Fixya
-jash
Apr 27, 2011 | YouTube Videos
Web page giving problems, when playing music from you tube, keeps on pausing
The speed of your Internet connection is not high-enough to download faster than the video-player is "consuming" the data. Press "pause" in your video-player, and wait 30 seconds for more of the download to happen. Then, press "play", to smoothly play what has been downloaded.
Feb 12, 2011 | Computers & Internet
Videos sop and freeze
The speed of your Internet connection is not enough to supply a "continuous" feed.
Start playing a video. Press the PAUSE key, and wait until the video is 50% downloaded. Press PLAY -- it should play "smoothly",
while the remaining 50% downloads.
Sep 27, 2010 | YouTube Videos
RESETING THE FULL ABSORBER
Waist reset code
1) With the printer turned off, hold down the RESUME button and press the POWER
button (the green indicator lights and the desired service function can be selected).
2) While holding down POWER button, let go of the RESUME button and then press the
RESUME button twice in succession. Then let go of the RESUME button and POWER
button.
(Each time you press the RESUME button, the indicator's color toggles between orange
and green.)
3) During printer initialization, the green indicator blinks. When the green indicator
stops blinking and remains on, press the RESUME button the stipulated number of
times to execute the desired service function listed below.
press 4 times indicator light should be green, this Clears the waste-ink counter.
4) After selecting the service function, press the POWER button. The green indicator
lights and the service function will be executed.
(After the respective function is executed, the printer returns to the service function
selection mode.)
To cancel printing after it begins, press the POWER button.
The Power lamp will blink for a while and then stay lit. You can then select
another service function.
Oct 22, 2009 | Canon Office Equipment & Supplies
Same problem
Press 1 after 9-9-1. The "1" code is the TV code.
Feb 23, 2008 | Jensen JR400 Remote Control
Philips DVP3120
You can follow the following instructions to make your philips dvp3120 player multi region!!!!!
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Jan 27, 2008 | Televison & Video
Apple iPhone 3G Logo
16 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
