Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
How to reset the Brother MFC 240C?
I installed new cartridges as requested and it does not recognize it. Still showing the old information.
    President:
  • 1,996 Answers
Be sure to answer the control panel question by pressing the up or down arrow key to answer yes. See here. and here.
If that doesn't work, try to reset the printer by following these instructions.
If you have other questions, you may be able to find a solution from your brother home support page here.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 05, 2009
Brother mfc-240c doesn't recognize ink cartridges that I put in
It may be a memory issue.
Unplug the machine from the power.
Remove all the ink cartridges
Replug the machine and reinstall the ink cartridges
Jan 19, 2010 | Brother Multi-Function Center MFC-240C...
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
I replaced the cayan ink cartridge, and it says there is no cartridge installed. I bought a second cartridge, and it still says that.
if you install the old empty cartridge and the message does not appear then the cartridge U have bought is not original
Jan 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
NO CARTRIDGE message when new cartridge installed
Make sure there is ink in all cartridges and unplug the machine. Plug it back in while you hold the stop key and it should clear the error.
Nov 23, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C has error message ''NO BLACK CARTRIDGE'' even though new cartridge is installed.
I learned this one from a Brother tech, and it usually works:
  1. Put your machine where you can easily reach the power plug.
  2. Lay a few layers of paper on the desk beside it to protect the desk from ink.
  3. With the machine plugged in, remove all four inks. Stand them upright on those papers you laid down.
  4. Close the top.
  5. Unplug the machine and wait 15 seconds before plugging it back in.
  6. Of course, the machine will complain that there is no ink installed. It should tell you which color it want you to install first. Raise the top and install all inks, in the order it asks.
  7. Lower the top when all the inks are in, and the machine should return to normal.
These machines detect ink by shining a light through a clear rib in the cartridge. What you've done resets the machine's threshold between light and dark, so it recognizes full cartridges again.
If it doesn't work, try it once more, and you might still get lucky. otherwise, you may have a defective cartridge, or you may need a new main board$$$.
Nov 08, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 490 is not recognizing off brand ink
try to remove the cartridge and put it back again after a while
Sep 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
HELP ON MFC-240C
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Sep 01, 2008 | Brother MFC 240C All-In-One InkJet Printer
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
Model mfc-240c
did you replace with brother carts, are you sure machine is refering to mag and yellew being mt, not the other ones, power off, remove all carts, power on , reinsert carts one at a time answer machine when prompted. these cartridges are deemed empty even when they look like they have a little ink left. Try putting in 4 new brother inks
Nov 09, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
1,521 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
