Question about Konica Minolta PagePro 1350W Laser Printer
Printer returns error message
I recently moved, and when I set up my Minolta PagePro 1350W, it won't print. The printer returns the error message: "There is a problem with the windows print spooler. This could be caused by: 1. Spooler is offline (reboot) or 2. No printer installed (reinstall)."
The last time I went through this, I downloaded the drivers and saved them on my hard drive. Now when I "install" it won't go through. Any suggestions? Should I uninstall everything and re-download the driver?
thanks,
Eric M.
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta pagepro 1350w fatal print spooler error?does that mean i need a new toner cartridge or is the damn thing busted?
A 'print spooler' is a range of memory either internal to the printer (sometimes called 'buffer memory') or set aside from the RAM in your system. A fatal error normally means the material you tried to print has been lost and must be sent to the printer again. If the error continues to show up, you may have bad printer memory or perhaps the driver software in your system has gotten stepped on by the operating system and needs to be reinstalled. Windows loves trashing files to keep life exciting.
This problem is not related to the drum or toner cartridge.
Oct 10, 2009 | Konica Minolta PagePro 1350W Laser Printer
I have a Konica Minolta pagepro 1350W printer. I
Please diregard. Since I was using an aftermarket toner cartridge, I took a chance and bought an OEM cartridge and... voila... it's working fine. Apparently, all I had was a bad cartridge.
Oct 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
PagePro 1350W won't pick up paper
Clean the rubber roller that draws the paper in with isoproply alcohol, in future, blow dust off top sheet in paper stack before printing.
May 19, 2009 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350w prints with streaks on left side
Hello sir; Not thing you can use forever if lifetime is out you need to change otherwise the streak line not go away.
May 13, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer won't print anymore
Go to printer faxes check and it might change the default setting and it might default Microsoft Office Document Image Writer. When you print make sure that you are printing to a right printer you can select the printer of your choice by clicking the down arrow. If you select the right printer and it did not print I suggest that uninstall the print driver to the control panel, add or remove and install a new printer driver. make sure set as a default.
Jan 27, 2009 | Konica Minolta PagePro 1350W Laser Printer
Only allows "print to file" will not allow printer to print.
you can go to printers and change the port to the virtual usb printer port....from the file port
Mar 30, 2008 | Konica Minolta PagePro 1350W Laser Printer
KONICA MINOLTA PagePro 1350W
the problem it might not be the printer. I encounter this problem before. the solution is uninstall the print driver to the control panel and re install the print driver using the cd print drive or you can download to konicaminolta web site..
Nov 21, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
154 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
