Question about Sharp LC-26D4U 26 in. LCD Television
My sharp aquos television sound is very low even on max.
My sharp aquos television sound is very low even when the volume is on maximum. could you help me?
I had this problem with my Charter and the box had a sound button on the actual box, not the remotes. Now I have switched to Direct TV Box and have found while not so low I can't hear it, it is much lower than I know it can be and have to turn it up in the higher numbers or turn on the surround sound to hear it. Anyone know what to do with Direct Box, Direct didn't know.
Posted on Sep 20, 2013
5 Suggested Answers
SOURCE: volume issue
I have the same problem. When I adjusted the volume on the cable box, it was solved. Turn up the volume on the cable box, and when you use your remote, it's super loud, even at midway!
Posted on May 20, 2008
SOURCE: Mono sound only
I have an LC42D64U with firmware U0709111. This is an 11 month old unit. It was working fine until I lost power one day, then I couldn't get any sound. It always showed up as Audio: mono. I tried every setting and nothing (although XBOX via HDMI still played though the onboard audio, so I knew it wasn't a HW issue).
After searching around for a method to change the mono/stereo I resorted to the Fred Flintstone's fix and simply pulled the plug on it. Immediately after turning it back on it worked.
This is hardly a fix but it worked for me.
Posted on Dec 10, 2008
  • 5 Answers
SOURCE: Volume is too low, even then it is turn up to the max.
Have you looked at the menu on your cable or satellite box to see if there is a seperate volume control for the box?
Usually it is found under
Settings>>Audio>>STB Volume
Posted on Apr 10, 2009
SOURCE: my sharp aquos has low volume
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
Posted on Sep 06, 2010
The volume is very low, even when I put it up to 60 (its maximum)
if you can open the TV try to connect external speaker to be sure that its the speakers and not the amplifier on the main Circuit
Aug 18, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
My sharp aquos has low volume
May 24, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
Feb 08, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to add more Sound, to my Sharp TV , even in the background, when watching movies, sound is very low , think its dew to cable service? Or would just like to Add external Rear Speakers?
The easiest would be installing a surround sound or other sound system that will amplify the audio. Also, some cable boxes actually have a volume control that is only found on the remote, try turning this up.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Apr 10, 2009 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Aquos maximum volume
There is only the vol level ctrl in the menu
Jun 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Sharp aquos LC 37D43U
If you have satellite, I am assuming you at least have a converter box hooked up. If so, make sure the converter box volume is set at its max. There may even be a volume setting in the converter menu that forces the volume output of the box to always be at full so that you don't get variations in audio when changing channels. Warning...before attempting this, please turn down the volume on your tv to at least the middle setting so you don't blow your tv speakers if this works.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Volume issue
Very loud it never gonna be. It's a tv with very small speakers, but I have a lot of customers who complain about that and I checked first the signal source. Sometimes the sattelite receiver or cable box give a sound not so good. The best way to check it is to plug something (an antenna or just a 2 inch wire) in the coaxial plug to see if on the tuner is the same sound. I bet is gonna be stronger.
Dec 29, 2007 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp LC-26D4U 26 in. LCD Television Logo
923 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
