Question about HP Computers & Internet
Hpm-705 crt monitor fault?
I am a technician and there is a fault in a CRT monitor i.e. HP m-705 model no.HSTNDS1A04-M. The fault is that when the monitor is on, the OSD menu(menu to adjust brightness,etc.) appears and then disappears afterwards automatically. And the brightness is very low and cannot be adjusted.
Please tell me that where is the fault in the circuit and how to solve it.
Tell as a professional as i am aware of this.
Switch prees no power on
Posted on Oct 11, 2010
My monitor model is HPm705 CRT as and when i use the system the monitor screen gets switched off and on every 2mins... pls consider the issue and tell the solution for it... to get resolve......
Posted on May 31, 2010
Crt monitor height are coming very small in size picture wat probelm
Did you set ur resolution screen setting higher than 1024 in ur computer panel resosulion setting?Yes than that is ur problems right there.CRT monitors modes are based on old technologies ,CRT monitors can't go up more than 1024 resolution setting.Setting resolution more than 1024 resolution for CRT models monitors will have thesse causes.The screen resolution on the screen will shrink and get smaller or will not have video resolution on the CRT monitors screens at all.Only LCD or LED monitors models can support and go higher than 1024 resolution setting has none of these causes.Time to upgrade for a new monitors technologies like LCD or LED monitors models.
Oct 17, 2012 | Computers & Internet
Compaq FS 7600 - display - CRT - 17" driver
click start control panel you will see thre options change theme change desktop background and adjust screen resolution then select resolution from the drop down list you can adjust to your preffered settings 1024x 768 is usually recomended (you have not stated your problem)
hope this helps
Sep 22, 2011 | HP Compaq FS7600 17" CRT Monitor
When i turn my monitor on it shows no picture and it makes a sound like it is running the electricty went out and when it came back on thats when the trouble started thank you
It's time to spend $100 to buy a brand-new 19-inch LCD monitor,
or $200 to buy a brand-new 22-inch LCD monitor,
rather than paying a TV/CRT technician $50 to $75 per hour to try to fix the "antique" monitor.
Aug 05, 2010 | HP Compaq P 1220 (Carbon, Silver) 22" CRT...
I have a CRT monitor hp 7650 and i have a problem that monitor power supply not working
I hate to sound nasty but these days it would be cheaper to buy a used but working CRT monitor than try to get one repaired. I've seen 22inch CRT's going for $10. Nobody wants them now there's LCD and LED monitors.
If you are really set on getting yours repaired, try Ebay. You may have to wait a few weeks for your specific model to come up but it could even be available right now. It may even be better to ask the seller to pull the power supply for you and just send it to save on freight.
Strange it's the exact model name for a scanjet too.
Good Luck
Apr 24, 2010 | HP Computers & Internet
The hp mx 705 monitor was working,then it just went blank and black. the power button light, just blinks green.
If the computer is attached properly and you get the flashing lights it is due to switch mode power supply being faulty, too expensive to fix I think you will find, never seems to be anything like just a fuse I'm afraid, modern worlds tells you its time for you next monitor..... do try to ensure it aint the pc by hooking laptop or something else to this unit, or hooking another monitor to your pc to be sure but I find power supply failure is normally how monitors leave this world...
Nov 07, 2009 | HP mx705 17" CRT Monitor
On screen display keeps appearing on, and usually
hi..i think you have a problem the CPU/Computer that's whystays on screen for so long.1st step check the IDE cable connection form the mother board to Hard Drive and 2nd check the memory or check all hardware`s.Good Luck and Have a nice day
Jun 17, 2009 | HP mx705 17" CRT Monitor
No Display on IBM G42 CRT Monitor's screen
if u change monitor . you came to know fault of monitor or cpu., if monitor works cpu is not woking properly..some itime we face same problem to creat by changining highgraphic. we can reduce graohic by using f8. re instiling xp we can solve that type of some problem.
Jun 15, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
Moniyor fault
How do you know the monitor is the problem? Try your computer with a different good monitor. If it has the same problem then the computer is at fault. If it works correctly then the monitor is at fault. Is this a CRT or LCD monitor? If it is a CRT monitor (with a big picture tube like old TVs) it would probably not be worth repairing. You can buy used ones pretty cheap. If it is a flat LCD monitor you would need to get a repair estimate and weigh that against the cost of a new one. Anything can be fixed but if repairs are more than new what would be the point?
Jan 06, 2009 | HP Computers & Internet
Hp mx 705 monitor the brightness menu appears andautomatically increases brightness to 100
Facing same issue in HP M704 from 12th Mar 08. It was working good for more than one year. Planning to contact customer support for service.
Mar 09, 2008 | HP mx705 17" CRT Monitor
Monitor problem
your monitor may not be switching on due to. 1 plug or socket loose or wire fault or not properly connected to computer. 2 there might be problem in power supply. 3 if it is ok there might problem in hor. section. it is not a major problem & can be easily rectified by skilled tech.
Sep 26, 2007 | HP S7540 17" CRT Monitor
Computers & Internet Logo
169 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
